Real estate bms
Mi intent is to use the logic machine to record consumption from 200 apartments, only active energy consumption. The devices are knx meters.
Ali we will have a smaller visually interface for building management 3 or 4 panels, nothing fancy.
Can you tell me that the device is power enough to deal with this request.
Also I want do be able to download the monthly consumption.
Latest hardware should handle this if you keep it with low resolution. I'm assuming that LM will not be doing anything else.
I would probably use 2 LMs anyway.
