i success to use chartist in offline mode !
It was a problem to one customer project. I was using google pie api... but this customer used it without internet access.
The doc:
http://gionkunz.github.io/chartist-js/examples.html
http://gionkunz.github.io/chartist-js/ge...arted.html
So here are my share.
I just add an image in the visualisation with class pie1
In custom javascript:
I also add the source script from here (chartist.min.js):
https://github.com/gionkunz/chartist-js/...aster/dist
I also add the source css from here (chartist.min.css) in the custom css:
I just have a little issue,
when the display update due to the object value send (grp.listen('20/3/200', function(obj, type) {)
The pie became little smaller than the 300px I setup. Not a big deal, but can't find why from now !
Here is the render:
The doc:
//instantane pie
$(function(){
var classImage ='pie1'
var idChart ='chart1'
const variableCourbes = ["20/3/0", "20/3/1", "20/3/2", "20/3/3", "20/3/4"];
var plans = $('.' + classImage)[0]
plans.innerHTML = '<div class="" id="'+ idChart + '"></div>';
var labelTab = [];
var serieTab = [];
var separateurNom = ' '
for (let i = 0; i < variableCourbes.length; i++) {
var id = Scada.encodeGroupAddress(variableCourbes[i]);
var obj = objectStore.getObject(id);
var nom = obj.name.split(separateurNom)[0]
labelTab.push(nom);
serieTab.push(obj.value);
var data = {
labels: labelTab,
series: serieTab
var options = {
width: 300+20,
height: 300+20,
donut: true,
donutWidth: 50,
donutSolid: true,
startAngle: 270,
showLabel: true
new Chartist.Pie('#'+idChart, data, options);
}, true);
/* Chartist.js 0.11.4
* Copyright 2019 Gion Kunz
* Free to use under either the WTFPL license or the MIT license.
* https://raw.githubusercontent.com/gionkunz/chartist-js/master/LICENSE-WTFPL
* https://raw.githubusercontent.com/gionkunz/chartist-js/master/LICENSE-MIT
!function(a,b){"function"==typeof define&&define.amd?define("Chartist",[],function(){return a.Chartist=b()}):"object"==typeof module&&module.exports?module.exports=b():a.Chartist=b()}(this,function(){var a={version:"0.11.4"};return function(a,b){"use strict";var c=a.window,d=a.document;b.namespaces={svg:"http://www.w3.org/2000/svg",xmlns:"http://www.w3.org/2000/xmlns/",xhtml:"http://www.w3.org/1999/xhtml",xlink:"http://www.w3.org/1999/xlink",ct:"http://gionkunz.github.com/chartist-js/ct"},b.noop=function(a){return a},b.alphaNumerate=function(a){return String.fromCharCode(97+a%26)},b.extend=function(a){var c,d,e;for(a=a||{},c=1;c<arguments.length;c++){d=arguments[c];for(var f in d)e=d[f],"object"!=typeof e||null===e||e instanceof Array?a[f]=e:a[f]=b.extend(a[f],e)}return a},b.replaceAll=function(a,b,c){return a.replace(new RegExp(b,"g"),c)},b.ensureUnit=function(a,b){return"number"==typeof a&&(a+=b),a},b.quantity=function(a){if("string"==typeof a){var b=/^(\d+)\s*(.*)$/g.exec(a);return{value:+b[1],unit:b[2]||void 0}}return{value:a}},b.querySelector=function(a){return a instanceof Node?a:d.querySelector(a)},b.times=function(a){return Array.apply(null,new Array(a))},b.sum=function(a,b){return a+(b?b:0)},b.mapMultiply=function(a){return function(b){return b*a}},b.mapAdd=function(a){return function(b){return b+a}},b.serialMap=function(a,c){var d=[],e=Math.max.apply(null,a.map(function(a){return a.length}));return b.times(e).forEach(function(b,e){var f=a.map(function(a){return a[e]});d[e]=c.apply(null,f)}),d},b.roundWithPrecision=function(a,c){var d=Math.pow(10,c||b.precision);return Math.round(a*d)/d},b.precision=8,b.escapingMap={"&":"&","<":"<",">":">",'"':""","'":"'"},b.serialize=function(a){return null===a||void 0===a?a:("number"==typeof a?a=""+a:"object"==typeof a&&(a=JSON.stringify({data:a})),Object.keys(b.escapingMap).reduce(function(a,c){return b.replaceAll(a,c,b.escapingMap[c])},a))},b.deserialize=function(a){if("string"!=typeof a)return a;a=Object.keys(b.escapingMap).reduce(function(a,c){return b.replaceAll(a,b.escapingMap[c],c)},a);try{a=JSON.parse(a),a=void 0!==a.data?a.data:a}catch(c){}return a},b.createSvg=function(a,c,d,e){var f;return c=c||"100%",d=d||"100%",Array.prototype.slice.call(a.querySelectorAll("svg")).filter(function(a){return a.getAttributeNS(b.namespaces.xmlns,"ct")}).forEach(function(b){a.removeChild(b)}),f=new b.Svg("svg").attr({width:c,height:d}).addClass(e),f._node.style.width=c,f._node.style.height=d,a.appendChild(f._node),f},b.normalizeData=function(a,c,d){var e,f={raw:a,normalized:{}};return f.normalized.series=b.getDataArray({series:a.series||[]},c,d),e=f.normalized.series.every(function(a){return a instanceof Array})?Math.max.apply(null,f.normalized.series.map(function(a){return a.length})):f.normalized.series.length,f.normalized.labels=(a.labels||[]).slice(),Array.prototype.push.apply(f.normalized.labels,b.times(Math.max(0,e-f.normalized.labels.length)).map(function(){return""})),c&&b.reverseData(f.normalized),f},b.safeHasProperty=function(a,b){return null!==a&&"object"==typeof a&&a.hasOwnProperty(b)},b.isDataHoleValue=function(a){return null===a||void 0===a||"number"==typeof a&&isNaN(a)},b.reverseData=function(a){a.labels.reverse(),a.series.reverse();for(var b=0;b<a.series.length;b++)"object"==typeof a.series[b]&&void 0!==a.series[b].data?a.series[b].data.reverse():a.series[b]instanceof Array&&a.series[b].reverse()},b.getDataArray=function(a,c,d){function e(a){if(b.safeHasProperty(a,"value"))return e(a.value);if(b.safeHasProperty(a,"data"))return e(a.data);if(a instanceof Array)return a.map(e);if(!b.isDataHoleValue(a)){if(d){var c={};return"string"==typeof d?c[d]=b.getNumberOrUndefined(a):c.y=b.getNumberOrUndefined(a),c.x=a.hasOwnProperty("x")?b.getNumberOrUndefined(a.x):c.x,c.y=a.hasOwnProperty("y")?b.getNumberOrUndefined(a.y):c.y,c}return b.getNumberOrUndefined(a)}}return a.series.map(e)},b.normalizePadding=function(a,b){return b=b||0,"number"==typeof a?{top:a,right:a,bottom:a,left:a}:{top:"number"==typeof a.top?a.top:b,right:"number"==typeof a.right?a.right:b,bottom:"number"==typeof a.bottom?a.bottom:b,left:"number"==typeof a.left?a.left:b}},b.getMetaData=function(a,b){var c=a.data?a.data[b]:a[b];return c?c.meta:void 0},b.orderOfMagnitude=function(a){return Math.floor(Math.log(Math.abs(a))/Math.LN10)},b.projectLength=function(a,b,c){return b/c.range*a},b.getAvailableHeight=function(a,c){return Math.max((b.quantity(c.height).value||a.height())-(c.chartPadding.top+c.chartPadding.bottom)-c.axisX.offset,0)},b.getHighLow=function(a,c,d){function e(a){if(void 0!==a)if(a instanceof Array)for(var b=0;b<a.length;b++)e(a[b]);else{var c=d?+a[d]:+a;g&&c>f.high&&(f.high=c),h&&c<f.low&&(f.low=c)}}c=b.extend({},c,d?c["axis"+d.toUpperCase()]:{});var f={high:void 0===c.high?-Number.MAX_VALUE:+c.high,low:void 0===c.low?Number.MAX_VALUE:+c.low},g=void 0===c.high,h=void 0===c.low;return(g||h)&&e(a),(c.referenceValue||0===c.referenceValue)&&(f.high=Math.max(c.referenceValue,f.high),f.low=Math.min(c.referenceValue,f.low)),f.high<=f.low&&(0===f.low?f.high=1:f.low<0?f.high=0:f.high>0?f.low=0:(f.high=1,f.low=0)),f},b.isNumeric=function(a){return null!==a&&isFinite(a)},b.isFalseyButZero=function(a){return!a&&0!==a},b.getNumberOrUndefined=function(a){return b.isNumeric(a)?+a:void 0},b.isMultiValue=function(a){return"object"==typeof a&&("x"in a||"y"in a)},b.getMultiValue=function(a,c){return b.isMultiValue(a)?b.getNumberOrUndefined(a[c||"y"]):b.getNumberOrUndefined(a)},b.rho=function(a){function b(a,c){return a%c===0?c:b(c,a%c)}function c(a){return a*a+1}if(1===a)return a;var d,e=2,f=2;if(a%2===0)return 2;do e=c(e)%a,f=c(c(f))%a,d=b(Math.abs(e-f),a);while(1===d);return d},b.getBounds=function(a,c,d,e){function f(a,b){return a===(a+=b)&&(a*=1+(b>0?o:-o)),a}var g,h,i,j=0,k={high:c.high,low:c.low};k.valueRange=k.high-k.low,k.oom=b.orderOfMagnitude(k.valueRange),k.step=Math.pow(10,k.oom),k.min=Math.floor(k.low/k.step)*k.step,k.max=Math.ceil(k.high/k.step)*k.step,k.range=k.max-k.min,k.numberOfSteps=Math.round(k.range/k.step);var l=b.projectLength(a,k.step,k),m=l<d,n=e?b.rho(k.range):0;if(e&&b.projectLength(a,1,k)>=d)k.step=1;else if(e&&n<k.step&&b.projectLength(a,n,k)>=d)k.step=n;else for(;;){if(m&&b.projectLength(a,k.step,k)<=d)k.step*=2;else{if(m||!(b.projectLength(a,k.step/2,k)>=d))break;if(k.step/=2,e&&k.step%1!==0){k.step*=2;break}}if(j++>1e3)throw new Error("Exceeded maximum number of iterations while optimizing scale step!")}var o=2.221e-16;for(k.step=Math.max(k.step,o),h=k.min,i=k.max;h+k.step<=k.low;)h=f(h,k.step);for(;i-k.step>=k.high;)i=f(i,-k.step);k.min=h,k.max=i,k.range=k.max-k.min;var p=[];for(g=k.min;g<=k.max;g=f(g,k.step)){var q=b.roundWithPrecision(g);q!==p[p.length-1]&&p.push(q)}return k.values=p,k},b.polarToCartesian=function(a,b,c,d){var e=(d-90)*Math.PI/180;return{x:a+c*Math.cos(e),y:b+c*Math.sin(e)}},b.createChartRect=function(a,c,d){var e=!(!c.axisX&&!c.axisY),f=e?c.axisY.offset:0,g=e?c.axisX.offset:0,h=a.width()||b.quantity(c.width).value||0,i=a.height()||b.quantity(c.height).value||0,j=b.normalizePadding(c.chartPadding,d);h=Math.max(h,f+j.left+j.right),i=Math.max(i,g+j.top+j.bottom);var k={padding:j,width:function(){return this.x2-this.x1},height:function(){return this.y1-this.y2}};return e?("start"===c.axisX.position?(k.y2=j.top+g,k.y1=Math.max(i-j.bottom,k.y2+1)):(k.y2=j.top,k.y1=Math.max(i-j.bottom-g,k.y2+1)),"start"===c.axisY.position?(k.x1=j.left+f,k.x2=Math.max(h-j.right,k.x1+1)):(k.x1=j.left,k.x2=Math.max(h-j.right-f,k.x1+1))):(k.x1=j.left,k.x2=Math.max(h-j.right,k.x1+1),k.y2=j.top,k.y1=Math.max(i-j.bottom,k.y2+1)),k},b.createGrid=function(a,c,d,e,f,g,h,i){var j={};j[d.units.pos+"1"]=a,j[d.units.pos+"2"]=a,j[d.counterUnits.pos+"1"]=e,j[d.counterUnits.pos+"2"]=e+f;var k=g.elem("line",j,h.join(" "));i.emit("draw",b.extend({type:"grid",axis:d,index:c,group:g,element:k},j))},b.createGridBackground=function(a,b,c,d){var e=a.elem("rect",{x:b.x1,y:b.y2,width:b.width(),height:b.height()},c,!0);d.emit("draw",{type:"gridBackground",group:a,element:e})},b.createLabel=function(a,c,e,f,g,h,i,j,k,l,m){var n,o={};if(o[g.units.pos]=a+i[g.units.pos],o[g.counterUnits.pos]=i[g.counterUnits.pos],o[g.units.len]=c,o[g.counterUnits.len]=Math.max(0,h-10),l){var p=d.createElement("span");p.className=k.join(" "),p.setAttribute("xmlns",b.namespaces.xhtml),p.innerText=f[e],p.style[g.units.len]=Math.round(o[g.units.len])+"px",p.style[g.counterUnits.len]=Math.round(o[g.counterUnits.len])+"px",n=j.foreignObject(p,b.extend({style:"overflow: visible;"},o))}else n=j.elem("text",o,k.join(" ")).text(f[e]);m.emit("draw",b.extend({type:"label",axis:g,index:e,group:j,element:n,text:f[e]},o))},b.getSeriesOption=function(a,b,c){if(a.name&&b.series&&b.series[a.name]){var d=b.series[a.name];return d.hasOwnProperty(c)?d[c]:b[c]}return b[c]},b.optionsProvider=function(a,d,e){function f(a){var f=h;if(h=b.extend({},j),d)for(i=0;i<d.length;i++){var g=c.matchMedia(d[i][0]);g.matches&&(h=b.extend(h,d[i][1]))}e&&a&&e.emit("optionsChanged",{previousOptions:f,currentOptions:h})}function g(){k.forEach(function(a){a.removeListener(f)})}var h,i,j=b.extend({},a),k=[];if(!c.matchMedia)throw"window.matchMedia not found! Make sure you're using a polyfill.";if(d)for(i=0;i<d.length;i++){var l=c.matchMedia(d[i][0]);l.addListener(f),k.push(l)}return f(),{removeMediaQueryListeners:g,getCurrentOptions:function(){return b.extend({},h)}}},b.splitIntoSegments=function(a,c,d){var e={increasingX:!1,fillHoles:!1};d=b.extend({},e,d);for(var f=[],g=!0,h=0;h<a.length;h+=2)void 0===b.getMultiValue(c[h/2].value)?d.fillHoles||(g=!0):(d.increasingX&&h>=2&&a[h]<=a[h-2]&&(g=!0),g&&(f.push({pathCoordinates:[],valueData:[]}),g=!1),f[f.length-1].pathCoordinates.push(a[h],a[h+1]),f[f.length-1].valueData.push(c[h/2]));return f}}(this||global,a),function(a,b){"use strict";b.Interpolation={},b.Interpolation.none=function(a){var c={fillHoles:!1};return a=b.extend({},c,a),function(c,d){for(var e=new b.Svg.Path,f=!0,g=0;g<c.length;g+=2){var h=c[g],i=c[g+1],j=d[g/2];void 0!==b.getMultiValue(j.value)?(f?e.move(h,i,!1,j):e.line(h,i,!1,j),f=!1):a.fillHoles||(f=!0)}return e}},b.Interpolation.simple=function(a){var c={divisor:2,fillHoles:!1};a=b.extend({},c,a);var d=1/Math.max(1,a.divisor);return function(c,e){for(var f,g,h,i=new b.Svg.Path,j=0;j<c.length;j+=2){var k=c[j],l=c[j+1],m=(k-f)*d,n=e[j/2];void 0!==n.value?(void 0===h?i.move(k,l,!1,n):i.curve(f+m,g,k-m,l,k,l,!1,n),f=k,g=l,h=n):a.fillHoles||(f=k=h=void 0)}return i}},b.Interpolation.cardinal=function(a){var c={tension:1,fillHoles:!1};a=b.extend({},c,a);var d=Math.min(1,Math.max(0,a.tension)),e=1-d;return function f(c,g){var h=b.splitIntoSegments(c,g,{fillHoles:a.fillHoles});if(h.length){if(h.length>1){var i=[];return h.forEach(function(a){i.push(f(a.pathCoordinates,a.valueData))}),b.Svg.Path.join(i)}if(c=h[0].pathCoordinates,g=h[0].valueData,c.length<=4)return b.Interpolation.none()(c,g);for(var j,k=(new b.Svg.Path).move(c[0],c[1],!1,g[0]),l=0,m=c.length;m-2*!j>l;l+=2){var n=[{x:+c[l-2],y:+c[l-1]},{x:+c[l],y:+c[l+1]},{x:+c[l+2],y:+c[l+3]},{x:+c[l+4],y:+c[l+5]}];j?l?m-4===l?n[3]={x:+c[0],y:+c[1]}:m-2===l&&(n[2]={x:+c[0],y:+c[1]},n[3]={x:+c[2],y:+c[3]}):n[0]={x:+c[m-2],y:+c[m-1]}:m-4===l?n[3]=n[2]:l||(n[0]={x:+c[l],y:+c[l+1]}),k.curve(d*(-n[0].x+6*n[1].x+n[2].x)/6+e*n[2].x,d*(-n[0].y+6*n[1].y+n[2].y)/6+e*n[2].y,d*(n[1].x+6*n[2].x-n[3].x)/6+e*n[2].x,d*(n[1].y+6*n[2].y-n[3].y)/6+e*n[2].y,n[2].x,n[2].y,!1,g[(l+2)/2])}return k}return b.Interpolation.none()([])}},b.Interpolation.monotoneCubic=function(a){var c={fillHoles:!1};return a=b.extend({},c,a),function d(c,e){var f=b.splitIntoSegments(c,e,{fillHoles:a.fillHoles,increasingX:!0});if(f.length){if(f.length>1){var g=[];return f.forEach(function(a){g.push(d(a.pathCoordinates,a.valueData))}),b.Svg.Path.join(g)}if(c=f[0].pathCoordinates,e=f[0].valueData,c.length<=4)return b.Interpolation.none()(c,e);var h,i,j=[],k=[],l=c.length/2,m=[],n=[],o=[],p=[];for(h=0;h<l;h++)j[h]=c[2*h],k[h]=c[2*h+1];for(h=0;h<l-1;h++)o[h]=k[h+1]-k[h],p[h]=j[h+1]-j[h],n[h]=o[h]/p[h];for(m[0]=n[0],m[l-1]=n[l-2],h=1;h<l-1;h++)0===n[h]||0===n[h-1]||n[h-1]>0!=n[h]>0?m[h]=0:(m[h]=3*(p[h-1]+p[h])/((2*p[h]+p[h-1])/n[h-1]+(p[h]+2*p[h-1])/n[h]),isFinite(m[h])||(m[h]=0));for(i=(new b.Svg.Path).move(j[0],k[0],!1,e[0]),h=0;h<l-1;h++)i.curve(j[h]+p[h]/3,k[h]+m[h]*p[h]/3,j[h+1]-p[h]/3,k[h+1]-m[h+1]*p[h]/3,j[h+1],k[h+1],!1,e[h+1]);return i}return b.Interpolation.none()([])}},b.Interpolation.step=function(a){var c={postpone:!0,fillHoles:!1};return a=b.extend({},c,a),function(c,d){for(var e,f,g,h=new b.Svg.Path,i=0;i<c.length;i+=2){var j=c[i],k=c[i+1],l=d[i/2];void 0!==l.value?(void 0===g?h.move(j,k,!1,l):(a.postpone?h.line(j,f,!1,g):h.line(e,k,!1,l),h.line(j,k,!1,l)),e=j,f=k,g=l):a.fillHoles||(e=f=g=void 0)}return h}}}(this||global,a),function(a,b){"use strict";b.EventEmitter=function(){function a(a,b){d[a]=d[a]||[],d[a].push(b)}function b(a,b){d[a]&&(b?(d[a].splice(d[a].indexOf(b),1),0===d[a].length&&delete d[a]):delete d[a])}function c(a,b){d[a]&&d[a].forEach(function(a){a(b)}),d["*"]&&d["*"].forEach(function(c){c(a,b)})}var d=[];return{addEventHandler:a,removeEventHandler:b,emit:c}}}(this||global,a),function(a,b){"use strict";function c(a){var b=[];if(a.length)for(var c=0;c<a.length;c++)b.push(a[c]);return b}function d(a,c){var d=c||this.prototype||b.Class,e=Object.create(d);b.Class.cloneDefinitions(e,a);var f=function(){var a,c=e.constructor||function(){};return a=this===b?Object.create(e):this,c.apply(a,Array.prototype.slice.call(arguments,0)),a};return f.prototype=e,f["super"]=d,f.extend=this.extend,f}function e(){var a=c(arguments),b=a[0];return a.splice(1,a.length-1).forEach(function(a){Object.getOwnPropertyNames(a).forEach(function(c){delete b[c],Object.defineProperty(b,c,Object.getOwnPropertyDescriptor(a,c))})}),b}b.Class={extend:d,cloneDefinitions:e}}(this||global,a),function(a,b){"use strict";function c(a,c,d){return a&&(this.data=a||{},this.data.labels=this.data.labels||[],this.data.series=this.data.series||[],this.eventEmitter.emit("data",{type:"update",data:this.data})),c&&(this.options=b.extend({},d?this.options:this.defaultOptions,c),this.initializeTimeoutId||(this.optionsProvider.removeMediaQueryListeners(),this.optionsProvider=b.optionsProvider(this.options,this.responsiveOptions,this.eventEmitter))),this.initializeTimeoutId||this.createChart(this.optionsProvider.getCurrentOptions()),this}function d(){return this.initializeTimeoutId?i.clearTimeout(this.initializeTimeoutId):(i.removeEventListener("resize",this.resizeListener),this.optionsProvider.removeMediaQueryListeners()),this}function e(a,b){return this.eventEmitter.addEventHandler(a,b),this}function f(a,b){return this.eventEmitter.removeEventHandler(a,b),this}function g(){i.addEventListener("resize",this.resizeListener),this.optionsProvider=b.optionsProvider(this.options,this.responsiveOptions,this.eventEmitter),this.eventEmitter.addEventHandler("optionsChanged",function(){this.update()}.bind(this)),this.options.plugins&&this.options.plugins.forEach(function(a){a instanceof Array?a[0](this,a[1]):a(this)}.bind(this)),this.eventEmitter.emit("data",{type:"initial",data:this.data}),this.createChart(this.optionsProvider.getCurrentOptions()),this.initializeTimeoutId=void 0}function h(a,c,d,e,f){this.container=b.querySelector(a),this.data=c||{},this.data.labels=this.data.labels||[],this.data.series=this.data.series||[],this.defaultOptions=d,this.options=e,this.responsiveOptions=f,this.eventEmitter=b.EventEmitter(),this.supportsForeignObject=b.Svg.isSupported("Extensibility"),this.supportsAnimations=b.Svg.isSupported("AnimationEventsAttribute"),this.resizeListener=function(){this.update()}.bind(this),this.container&&(this.container.__chartist__&&this.container.__chartist__.detach(),this.container.__chartist__=this),this.initializeTimeoutId=setTimeout(g.bind(this),0)}var i=a.window;b.Base=b.Class.extend({constructor:h,optionsProvider:void 0,container:void 0,svg:void 0,eventEmitter:void 0,createChart:function(){throw new Error("Base chart type can't be instantiated!")},update:c,detach:d,on:e,off:f,version:b.version,supportsForeignObject:!1})}(this||global,a),function(a,b){"use strict";function c(a,c,d,e,f){a instanceof Element?this._node=a:(this._node=y.createElementNS(b.namespaces.svg,a),"svg"===a&&this.attr({"xmlns:ct":b.namespaces.ct})),c&&this.attr(c),d&&this.addClass(d),e&&(f&&e._node.firstChild?e._node.insertBefore(this._node,e._node.firstChild):e._node.appendChild(this._node))}function d(a,c){return"string"==typeof a?c?this._node.getAttributeNS(c,a):this._node.getAttribute(a):(Object.keys(a).forEach(function(c){if(void 0!==a[c])if(c.indexOf(":")!==-1){var d=c.split(":");this._node.setAttributeNS(b.namespaces[d[0]],c,a[c])}else this._node.setAttribute(c,a[c])}.bind(this)),this)}function e(a,c,d,e){return new b.Svg(a,c,d,this,e)}function f(){return this._node.parentNode instanceof SVGElement?new b.Svg(this._node.parentNode):null}function g(){for(var a=this._node;"svg"!==a.nodeName;)a=a.parentNode;return new b.Svg(a)}function h(a){var c=this._node.querySelector(a);return c?new b.Svg(c):null}function i(a){var c=this._node.querySelectorAll(a);return c.length?new b.Svg.List(c):null}function j(){return this._node}function k(a,c,d,e){if("string"==typeof a){var f=y.createElement("div");f.innerHTML=a,a=f.firstChild}a.setAttribute("xmlns",b.namespaces.xmlns);var g=this.elem("foreignObject",c,d,e);return g._node.appendChild(a),g}function l(a){return this._node.appendChild(y.createTextNode(a)),this}function m(){for(;this._node.firstChild;)this._node.removeChild(this._node.firstChild);return this}function n(){return this._node.parentNode.removeChild(this._node),this.parent()}function o(a){return this._node.parentNode.replaceChild(a._node,this._node),a}function p(a,b){return b&&this._node.firstChild?this._node.insertBefore(a._node,this._node.firstChild):this._node.appendChild(a._node),this}function q(){return this._node.getAttribute("class")?this._node.getAttribute("class").trim().split(/\s+/):[]}function r(a){return this._node.setAttribute("class",this.classes(this._node).concat(a.trim().split(/\s+/)).filter(function(a,b,c){return c.indexOf(a)===b}).join(" ")),this}function s(a){var b=a.trim().split(/\s+/);return this._node.setAttribute("class",this.classes(this._node).filter(function(a){return b.indexOf(a)===-1}).join(" ")),this}function t(){return this._node.setAttribute("class",""),this}function u(){return this._node.getBoundingClientRect().height}function v(){return this._node.getBoundingClientRect().width}function w(a,c,d){return void 0===c&&(c=!0),Object.keys(a).forEach(function(e){function f(a,c){var f,g,h,i={};a.easing&&(h=a.easing instanceof Array?a.easing:b.Svg.Easing[a.easing],delete a.easing),a.begin=b.ensureUnit(a.begin,"ms"),a.dur=b.ensureUnit(a.dur,"ms"),h&&(a.calcMode="spline",a.keySplines=h.join(" "),a.keyTimes="0;1"),c&&(a.fill="freeze",i[e]=a.from,this.attr(i),g=b.quantity(a.begin||0).value,a.begin="indefinite"),f=this.elem("animate",b.extend({attributeName:e},a)),c&&setTimeout(function(){try{f._node.beginElement()}catch(b){i[e]=a.to,this.attr(i),f.remove()}}.bind(this),g),d&&f._node.addEventListener("beginEvent",function(){d.emit("animationBegin",{element:this,animate:f._node,params:a})}.bind(this)),f._node.addEventListener("endEvent",function(){d&&d.emit("animationEnd",{element:this,animate:f._node,params:a}),c&&(i[e]=a.to,this.attr(i),f.remove())}.bind(this))}a[e]instanceof Array?a[e].forEach(function(a){f.bind(this)(a,!1)}.bind(this)):f.bind(this)(a[e],c)}.bind(this)),this}function x(a){var c=this;this.svgElements=[];for(var d=0;d<a.length;d++)this.svgElements.push(new b.Svg(a[d]));Object.keys(b.Svg.prototype).filter(function(a){return["constructor","parent","querySelector","querySelectorAll","replace","append","classes","height","width"].indexOf(a)===-1}).forEach(function(a){c[a]=function(){var d=Array.prototype.slice.call(arguments,0);return c.svgElements.forEach(function(c){b.Svg.prototype[a].apply(c,d)}),c}})}var y=a.document;b.Svg=b.Class.extend({constructor:c,attr:d,elem:e,parent:f,root:g,querySelector:h,querySelectorAll:i,getNode:j,foreignObject:k,text:l,empty:m,remove:n,replace:o,append:p,classes:q,addClass:r,removeClass:s,removeAllClasses:t,height:u,width:v,animate:w}),b.Svg.isSupported=function(a){return y.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#"+a,"1.1")};var z={easeInSine:[.47,0,.745,.715],easeOutSine:[.39,.575,.565,1],easeInOutSine:[.445,.05,.55,.95],easeInQuad:[.55,.085,.68,.53],easeOutQuad:[.25,.46,.45,.94],easeInOutQuad:[.455,.03,.515,.955],easeInCubic:[.55,.055,.675,.19],easeOutCubic:[.215,.61,.355,1],easeInOutCubic:[.645,.045,.355,1],easeInQuart:[.895,.03,.685,.22],easeOutQuart:[.165,.84,.44,1],easeInOutQuart:[.77,0,.175,1],easeInQuint:[.755,.05,.855,.06],easeOutQuint:[.23,1,.32,1],easeInOutQuint:[.86,0,.07,1],easeInExpo:[.95,.05,.795,.035],easeOutExpo:[.19,1,.22,1],easeInOutExpo:[1,0,0,1],easeInCirc:[.6,.04,.98,.335],easeOutCirc:[.075,.82,.165,1],easeInOutCirc:[.785,.135,.15,.86],easeInBack:[.6,-.28,.735,.045],easeOutBack:[.175,.885,.32,1.275],easeInOutBack:[.68,-.55,.265,1.55]};b.Svg.Easing=z,b.Svg.List=b.Class.extend({constructor:x})}(this||global,a),function(a,b){"use strict";function c(a,c,d,e,f,g){var h=b.extend({command:f?a.toLowerCase():a.toUpperCase()},c,g?{data:g}:{});d.splice(e,0,h)}function d(a,b){a.forEach(function(c,d){t[c.command.toLowerCase()].forEach(function(e,f){b(c,e,d,f,a)})})}function e(a,c){this.pathElements=[],this.pos=0,this.close=a,this.options=b.extend({},u,c)}function f(a){return void 0!==a?(this.pos=Math.max(0,Math.min(this.pathElements.length,a)),this):this.pos}function g(a){return this.pathElements.splice(this.pos,a),this}function h(a,b,d,e){return c("M",{x:+a,y:+b},this.pathElements,this.pos++,d,e),this}function i(a,b,d,e){return c("L",{x:+a,y:+b},this.pathElements,this.pos++,d,e),this}function j(a,b,d,e,f,g,h,i){return c("C",{x1:+a,y1:+b,x2:+d,y2:+e,x:+f,y:+g},this.pathElements,this.pos++,h,i),this}function k(a,b,d,e,f,g,h,i,j){return c("A",{rx:+a,ry:+b,xAr:+d,lAf:+e,sf:+f,x:+g,y:+h},this.pathElements,this.pos++,i,j),this}function l(a){var c=a.replace(/([A-Za-z])([0-9])/g,"$1 $2").replace(/([0-9])([A-Za-z])/g,"$1 $2").split(/[\s,]+/).reduce(function(a,b){return b.match(/[A-Za-z]/)&&a.push([]),a[a.length-1].push(b),a},[]);"Z"===c[c.length-1][0].toUpperCase()&&c.pop();var d=c.map(function(a){var c=a.shift(),d=t[c.toLowerCase()];return b.extend({command:c},d.reduce(function(b,c,d){return b[c]=+a[d],b},{}))}),e=[this.pos,0];return Array.prototype.push.apply(e,d),Array.prototype.splice.apply(this.pathElements,e),this.pos+=d.length,this}function m(){var a=Math.pow(10,this.options.accuracy);return this.pathElements.reduce(function(b,c){var d=t[c.command.toLowerCase()].map(function(b){return this.options.accuracy?Math.round(c[b]*a)/a:c[b]}.bind(this));return b+c.command+d.join(",")}.bind(this),"")+(this.close?"Z":"")}function n(a,b){return d(this.pathElements,function(c,d){c[d]*="x"===d[0]?a:b}),this}function o(a,b){return d(this.pathElements,function(c,d){c[d]+="x"===d[0]?a:b}),this}function p(a){return d(this.pathElements,function(b,c,d,e,f){var g=a(b,c,d,e,f);(g||0===g)&&(b[c]=g)}),this}function q(a){var c=new b.Svg.Path(a||this.close);return c.pos=this.pos,c.pathElements=this.pathElements.slice().map(function(a){return b.extend({},a)}),c.options=b.extend({},this.options),c}function r(a){var c=[new b.Svg.Path];return this.pathElements.forEach(function(d){d.command===a.toUpperCase()&&0!==c[c.length-1].pathElements.length&&c.push(new b.Svg.Path),c[c.length-1].pathElements.push(d)}),c}function s(a,c,d){for(var e=new b.Svg.Path(c,d),f=0;f<a.length;f++)for(var g=a[f],h=0;h<g.pathElements.length;h++)e.pathElements.push(g.pathElements[h]);return e}var t={m:["x","y"],l:["x","y"],c:["x1","y1","x2","y2","x","y"],a:["rx","ry","xAr","lAf","sf","x","y"]},u={accuracy:3};b.Svg.Path=b.Class.extend({constructor:e,position:f,remove:g,move:h,line:i,curve:j,arc:k,scale:n,translate:o,transform:p,parse:l,stringify:m,clone:q,splitByCommand:r}),b.Svg.Path.elementDescriptions=t,b.Svg.Path.join=s}(this||global,a),function(a,b){"use strict";function c(a,b,c,d){this.units=a,this.counterUnits=a===e.x?e.y:e.x,this.chartRect=b,this.axisLength=b[a.rectEnd]-b[a.rectStart],this.gridOffset=b[a.rectOffset],this.ticks=c,this.options=d}function d(a,c,d,e,f){var g=e["axis"+this.units.pos.toUpperCase()],h=this.ticks.map(this.projectValue.bind(this)),i=this.ticks.map(g.labelInterpolationFnc);h.forEach(function(j,k){var l,m={x:0,y:0};l=h[k+1]?h[k+1]-j:Math.max(this.axisLength-j,30),b.isFalseyButZero(i[k])&&""!==i[k]||("x"===this.units.pos?(j=this.chartRect.x1+j,m.x=e.axisX.labelOffset.x,"start"===e.axisX.position?m.y=this.chartRect.padding.top+e.axisX.labelOffset.y+(d?5:20):m.y=this.chartRect.y1+e.axisX.labelOffset.y+(d?5:20)):(j=this.chartRect.y1-j,m.y=e.axisY.labelOffset.y-(d?l:0),"start"===e.axisY.position?m.x=d?this.chartRect.padding.left+e.axisY.labelOffset.x:this.chartRect.x1-10:m.x=this.chartRect.x2+e.axisY.labelOffset.x+10),g.showGrid&&b.createGrid(j,k,this,this.gridOffset,this.chartRect[this.counterUnits.len](),a,[e.classNames.grid,e.classNames[this.units.dir]],f),g.showLabel&&b.createLabel(j,l,k,i,this,g.offset,m,c,[e.classNames.label,e.classNames[this.units.dir],"start"===g.position?e.classNames[g.position]:e.classNames.end],d,f))}.bind(this))}var e=(a.window,a.document,{x:{pos:"x",len:"width",dir:"horizontal",rectStart:"x1",rectEnd:"x2",rectOffset:"y2"},y:{pos:"y",len:"height",dir:"vertical",rectStart:"y2",rectEnd:"y1",rectOffset:"x1"}});b.Axis=b.Class.extend({constructor:c,createGridAndLabels:d,projectValue:function(a,b,c){throw new Error("Base axis can't be instantiated!")}}),b.Axis.units=e}(this||global,a),function(a,b){"use strict";function c(a,c,d,e){var f=e.highLow||b.getHighLow(c,e,a.pos);this.bounds=b.getBounds(d[a.rectEnd]-d[a.rectStart],f,e.scaleMinSpace||20,e.onlyInteger),this.range={min:this.bounds.min,max:this.bounds.max},b.AutoScaleAxis["super"].constructor.call(this,a,d,this.bounds.values,e)}function d(a){return this.axisLength*(+b.getMultiValue(a,this.units.pos)-this.bounds.min)/this.bounds.range}a.window,a.document;b.AutoScaleAxis=b.Axis.extend({constructor:c,projectValue:d})}(this||global,a),function(a,b){"use strict";function c(a,c,d,e){var f=e.highLow||b.getHighLow(c,e,a.pos);this.divisor=e.divisor||1,this.ticks=e.ticks||b.times(this.divisor).map(function(a,b){return f.low+(f.high-f.low)/this.divisor*b}.bind(this)),this.ticks.sort(function(a,b){return a-b}),this.range={min:f.low,max:f.high},b.FixedScaleAxis["super"].constructor.call(this,a,d,this.ticks,e),this.stepLength=this.axisLength/this.divisor}function d(a){return this.axisLength*(+b.getMultiValue(a,this.units.pos)-this.range.min)/(this.range.max-this.range.min)}a.window,a.document;b.FixedScaleAxis=b.Axis.extend({constructor:c,projectValue:d})}(this||global,a),function(a,b){"use strict";function c(a,c,d,e){b.StepAxis["super"].constructor.call(this,a,d,e.ticks,e);var f=Math.max(1,e.ticks.length-(e.stretch?1:0));this.stepLength=this.axisLength/f}function d(a,b){return this.stepLength*b}a.window,a.document;b.StepAxis=b.Axis.extend({constructor:c,projectValue:d})}(this||global,a),function(a,b){"use strict";function c(a){var c=b.normalizeData(this.data,a.reverseData,!0);this.svg=b.createSvg(this.container,a.width,a.height,a.classNames.chart);var d,f,g=this.svg.elem("g").addClass(a.classNames.gridGroup),h=this.svg.elem("g"),i=this.svg.elem("g").addClass(a.classNames.labelGroup),j=b.createChartRect(this.svg,a,e.padding);d=void 0===a.axisX.type?new b.StepAxis(b.Axis.units.x,c.normalized.series,j,b.extend({},a.axisX,{ticks:c.normalized.labels,stretch:a.fullWidth})):a.axisX.type.call(b,b.Axis.units.x,c.normalized.series,j,a.axisX),f=void 0===a.axisY.type?new b.AutoScaleAxis(b.Axis.units.y,c.normalized.series,j,b.extend({},a.axisY,{high:b.isNumeric(a.high)?a.high:a.axisY.high,low:b.isNumeric(a.low)?a.low:a.axisY.low})):a.axisY.type.call(b,b.Axis.units.y,c.normalized.series,j,a.axisY),d.createGridAndLabels(g,i,this.supportsForeignObject,a,this.eventEmitter),f.createGridAndLabels(g,i,this.supportsForeignObject,a,this.eventEmitter),a.showGridBackground&&b.createGridBackground(g,j,a.classNames.gridBackground,this.eventEmitter),c.raw.series.forEach(function(e,g){var i=h.elem("g");i.attr({"ct:series-name":e.name,"ct:meta":b.serialize(e.meta)}),i.addClass([a.classNames.series,e.className||a.classNames.series+"-"+b.alphaNumerate(g)].join(" "));var k=[],l=[];c.normalized.series[g].forEach(function(a,h){var i={x:j.x1+d.projectValue(a,h,c.normalized.series[g]),y:j.y1-f.projectValue(a,h,c.normalized.series[g])};k.push(i.x,i.y),l.push({value:a,valueIndex:h,meta:b.getMetaData(e,h)})}.bind(this));var m={lineSmooth:b.getSeriesOption(e,a,"lineSmooth"),showPoint:b.getSeriesOption(e,a,"showPoint"),showLine:b.getSeriesOption(e,a,"showLine"),showArea:b.getSeriesOption(e,a,"showArea"),areaBase:b.getSeriesOption(e,a,"areaBase")},n="function"==typeof m.lineSmooth?m.lineSmooth:m.lineSmooth?b.Interpolation.monotoneCubic():b.Interpolation.none(),o=n(k,l);if(m.showPoint&&o.pathElements.forEach(function(c){var h=i.elem("line",{x1:c.x,y1:c.y,x2:c.x+.01,y2:c.y},a.classNames.point).attr({"ct:value":[c.data.value.x,c.data.value.y].filter(b.isNumeric).join(","),"ct:meta":b.serialize(c.data.meta)});this.eventEmitter.emit("draw",{type:"point",value:c.data.value,index:c.data.valueIndex,meta:c.data.meta,series:e,seriesIndex:g,axisX:d,axisY:f,group:i,element:h,x:c.x,y:c.y})}.bind(this)),m.showLine){var p=i.elem("path",{d:o.stringify()},a.classNames.line,!0);this.eventEmitter.emit("draw",{type:"line",values:c.normalized.series[g],path:o.clone(),chartRect:j,index:g,series:e,seriesIndex:g,seriesMeta:e.meta,axisX:d,axisY:f,group:i,element:p})}if(m.showArea&&f.range){var q=Math.max(Math.min(m.areaBase,f.range.max),f.range.min),r=j.y1-f.projectValue(q);o.splitByCommand("M").filter(function(a){return a.pathElements.length>1}).map(function(a){var b=a.pathElements[0],c=a.pathElements[a.pathElements.length-1];return a.clone(!0).position(0).remove(1).move(b.x,r).line(b.x,b.y).position(a.pathElements.length+1).line(c.x,r)}).forEach(function(b){var h=i.elem("path",{d:b.stringify()},a.classNames.area,!0);this.eventEmitter.emit("draw",{type:"area",values:c.normalized.series[g],path:b.clone(),series:e,seriesIndex:g,axisX:d,axisY:f,chartRect:j,index:g,group:i,element:h})}.bind(this))}}.bind(this)),this.eventEmitter.emit("created",{bounds:f.bounds,chartRect:j,axisX:d,axisY:f,svg:this.svg,options:a})}function d(a,c,d,f){b.Line["super"].constructor.call(this,a,c,e,b.extend({},e,d),f)}var e=(a.window,a.document,{axisX:{offset:30,position:"end",labelOffset:{x:0,y:0},showLabel:!0,showGrid:!0,labelInterpolationFnc:b.noop,type:void 0},axisY:{offset:40,position:"start",labelOffset:{x:0,y:0},showLabel:!0,showGrid:!0,labelInterpolationFnc:b.noop,type:void 0,scaleMinSpace:20,onlyInteger:!1},width:void 0,height:void 0,showLine:!0,showPoint:!0,showArea:!1,areaBase:0,lineSmooth:!0,showGridBackground:!1,low:void 0,high:void 0,chartPadding:{top:15,right:15,bottom:5,left:10},fullWidth:!1,reverseData:!1,classNames:{chart:"ct-chart-line",label:"ct-label",labelGroup:"ct-labels",series:"ct-series",line:"ct-line",point:"ct-point",area:"ct-area",grid:"ct-grid",gridGroup:"ct-grids",gridBackground:"ct-grid-background",vertical:"ct-vertical",horizontal:"ct-horizontal",start:"ct-start",end:"ct-end"}});b.Line=b.Base.extend({constructor:d,createChart:c})}(this||global,a),function(a,b){"use strict";function c(a){var c,d;a.distributeSeries?(c=b.normalizeData(this.data,a.reverseData,a.horizontalBars?"x":"y"),c.normalized.series=c.normalized.series.map(function(a){return[a]})):c=b.normalizeData(this.data,a.reverseData,a.horizontalBars?"x":"y"),this.svg=b.createSvg(this.container,a.width,a.height,a.classNames.chart+(a.horizontalBars?" "+a.classNames.horizontalBars:""));var f=this.svg.elem("g").addClass(a.classNames.gridGroup),g=this.svg.elem("g"),h=this.svg.elem("g").addClass(a.classNames.labelGroup);
if(a.stackBars&&0!==c.normalized.series.length){var i=b.serialMap(c.normalized.series,function(){return Array.prototype.slice.call(arguments).map(function(a){return a}).reduce(function(a,b){return{x:a.x+(b&&b.x)||0,y:a.y+(b&&b.y)||0}},{x:0,y:0})});d=b.getHighLow([i],a,a.horizontalBars?"x":"y")}else d=b.getHighLow(c.normalized.series,a,a.horizontalBars?"x":"y");d.high=+a.high||(0===a.high?0:d.high),d.low=+a.low||(0===a.low?0:d.low);var j,k,l,m,n,o=b.createChartRect(this.svg,a,e.padding);k=a.distributeSeries&&a.stackBars?c.normalized.labels.slice(0,1):c.normalized.labels,a.horizontalBars?(j=m=void 0===a.axisX.type?new b.AutoScaleAxis(b.Axis.units.x,c.normalized.series,o,b.extend({},a.axisX,{highLow:d,referenceValue:0})):a.axisX.type.call(b,b.Axis.units.x,c.normalized.series,o,b.extend({},a.axisX,{highLow:d,referenceValue:0})),l=n=void 0===a.axisY.type?new b.StepAxis(b.Axis.units.y,c.normalized.series,o,{ticks:k}):a.axisY.type.call(b,b.Axis.units.y,c.normalized.series,o,a.axisY)):(l=m=void 0===a.axisX.type?new b.StepAxis(b.Axis.units.x,c.normalized.series,o,{ticks:k}):a.axisX.type.call(b,b.Axis.units.x,c.normalized.series,o,a.axisX),j=n=void 0===a.axisY.type?new b.AutoScaleAxis(b.Axis.units.y,c.normalized.series,o,b.extend({},a.axisY,{highLow:d,referenceValue:0})):a.axisY.type.call(b,b.Axis.units.y,c.normalized.series,o,b.extend({},a.axisY,{highLow:d,referenceValue:0})));var p=a.horizontalBars?o.x1+j.projectValue(0):o.y1-j.projectValue(0),q=[];l.createGridAndLabels(f,h,this.supportsForeignObject,a,this.eventEmitter),j.createGridAndLabels(f,h,this.supportsForeignObject,a,this.eventEmitter),a.showGridBackground&&b.createGridBackground(f,o,a.classNames.gridBackground,this.eventEmitter),c.raw.series.forEach(function(d,e){var f,h,i=e-(c.raw.series.length-1)/2;f=a.distributeSeries&&!a.stackBars?l.axisLength/c.normalized.series.length/2:a.distributeSeries&&a.stackBars?l.axisLength/2:l.axisLength/c.normalized.series[e].length/2,h=g.elem("g"),h.attr({"ct:series-name":d.name,"ct:meta":b.serialize(d.meta)}),h.addClass([a.classNames.series,d.className||a.classNames.series+"-"+b.alphaNumerate(e)].join(" ")),c.normalized.series[e].forEach(function(g,k){var r,s,t,u;if(u=a.distributeSeries&&!a.stackBars?e:a.distributeSeries&&a.stackBars?0:k,r=a.horizontalBars?{x:o.x1+j.projectValue(g&&g.x?g.x:0,k,c.normalized.series[e]),y:o.y1-l.projectValue(g&&g.y?g.y:0,u,c.normalized.series[e])}:{x:o.x1+l.projectValue(g&&g.x?g.x:0,u,c.normalized.series[e]),y:o.y1-j.projectValue(g&&g.y?g.y:0,k,c.normalized.series[e])},l instanceof b.StepAxis&&(l.options.stretch||(r[l.units.pos]+=f*(a.horizontalBars?-1:1)),r[l.units.pos]+=a.stackBars||a.distributeSeries?0:i*a.seriesBarDistance*(a.horizontalBars?-1:1)),t=q[k]||p,q[k]=t-(p-r[l.counterUnits.pos]),void 0!==g){var v={};v[l.units.pos+"1"]=r[l.units.pos],v[l.units.pos+"2"]=r[l.units.pos],!a.stackBars||"accumulate"!==a.stackMode&&a.stackMode?(v[l.counterUnits.pos+"1"]=p,v[l.counterUnits.pos+"2"]=r[l.counterUnits.pos]):(v[l.counterUnits.pos+"1"]=t,v[l.counterUnits.pos+"2"]=q[k]),v.x1=Math.min(Math.max(v.x1,o.x1),o.x2),v.x2=Math.min(Math.max(v.x2,o.x1),o.x2),v.y1=Math.min(Math.max(v.y1,o.y2),o.y1),v.y2=Math.min(Math.max(v.y2,o.y2),o.y1);var w=b.getMetaData(d,k);s=h.elem("line",v,a.classNames.bar).attr({"ct:value":[g.x,g.y].filter(b.isNumeric).join(","),"ct:meta":b.serialize(w)}),this.eventEmitter.emit("draw",b.extend({type:"bar",value:g,index:k,meta:w,series:d,seriesIndex:e,axisX:m,axisY:n,chartRect:o,group:h,element:s},v))}}.bind(this))}.bind(this)),this.eventEmitter.emit("created",{bounds:j.bounds,chartRect:o,axisX:m,axisY:n,svg:this.svg,options:a})}function d(a,c,d,f){b.Bar["super"].constructor.call(this,a,c,e,b.extend({},e,d),f)}var e=(a.window,a.document,{axisX:{offset:30,position:"end",labelOffset:{x:0,y:0},showLabel:!0,showGrid:!0,labelInterpolationFnc:b.noop,scaleMinSpace:30,onlyInteger:!1},axisY:{offset:40,position:"start",labelOffset:{x:0,y:0},showLabel:!0,showGrid:!0,labelInterpolationFnc:b.noop,scaleMinSpace:20,onlyInteger:!1},width:void 0,height:void 0,high:void 0,low:void 0,referenceValue:0,chartPadding:{top:15,right:15,bottom:5,left:10},seriesBarDistance:15,stackBars:!1,stackMode:"accumulate",horizontalBars:!1,distributeSeries:!1,reverseData:!1,showGridBackground:!1,classNames:{chart:"ct-chart-bar",horizontalBars:"ct-horizontal-bars",label:"ct-label",labelGroup:"ct-labels",series:"ct-series",bar:"ct-bar",grid:"ct-grid",gridGroup:"ct-grids",gridBackground:"ct-grid-background",vertical:"ct-vertical",horizontal:"ct-horizontal",start:"ct-start",end:"ct-end"}});b.Bar=b.Base.extend({constructor:d,createChart:c})}(this||global,a),function(a,b){"use strict";function c(a,b,c){var d=b.x>a.x;return d&&"explode"===c||!d&&"implode"===c?"start":d&&"implode"===c||!d&&"explode"===c?"end":"middle"}function d(a){var d,e,g,h,i,j=b.normalizeData(this.data),k=[],l=a.startAngle;this.svg=b.createSvg(this.container,a.width,a.height,a.donut?a.classNames.chartDonut:a.classNames.chartPie),e=b.createChartRect(this.svg,a,f.padding),g=Math.min(e.width()/2,e.height()/2),i=a.total||j.normalized.series.reduce(function(a,b){return a+b},0);var m=b.quantity(a.donutWidth);"%"===m.unit&&(m.value*=g/100),g-=a.donut&&!a.donutSolid?m.value/2:0,h="outside"===a.labelPosition||a.donut&&!a.donutSolid?g:"center"===a.labelPosition?0:a.donutSolid?g-m.value/2:g/2,h+=a.labelOffset;var n={x:e.x1+e.width()/2,y:e.y2+e.height()/2},o=1===j.raw.series.filter(function(a){return a.hasOwnProperty("value")?0!==a.value:0!==a}).length;j.raw.series.forEach(function(a,b){k[b]=this.svg.elem("g",null,null)}.bind(this)),a.showLabel&&(d=this.svg.elem("g",null,null)),j.raw.series.forEach(function(e,f){if(0!==j.normalized.series[f]||!a.ignoreEmptyValues){k[f].attr({"ct:series-name":e.name}),k[f].addClass([a.classNames.series,e.className||a.classNames.series+"-"+b.alphaNumerate(f)].join(" "));var p=i>0?l+j.normalized.series[f]/i*360:0,q=Math.max(0,l-(0===f||o?0:.2));p-q>=359.99&&(p=q+359.99);var r,s,t,u=b.polarToCartesian(n.x,n.y,g,q),v=b.polarToCartesian(n.x,n.y,g,p),w=new b.Svg.Path(!a.donut||a.donutSolid).move(v.x,v.y).arc(g,g,0,p-l>180,0,u.x,u.y);a.donut?a.donutSolid&&(t=g-m.value,r=b.polarToCartesian(n.x,n.y,t,l-(0===f||o?0:.2)),s=b.polarToCartesian(n.x,n.y,t,p),w.line(r.x,r.y),w.arc(t,t,0,p-l>180,1,s.x,s.y)):w.line(n.x,n.y);var x=a.classNames.slicePie;a.donut&&(x=a.classNames.sliceDonut,a.donutSolid&&(x=a.classNames.sliceDonutSolid));var y=k[f].elem("path",{d:w.stringify()},x);if(y.attr({"ct:value":j.normalized.series[f],"ct:meta":b.serialize(e.meta)}),a.donut&&!a.donutSolid&&(y._node.style.strokeWidth=m.value+"px"),this.eventEmitter.emit("draw",{type:"slice",value:j.normalized.series[f],totalDataSum:i,index:f,meta:e.meta,series:e,group:k[f],element:y,path:w.clone(),center:n,radius:g,startAngle:l,endAngle:p}),a.showLabel){var z;z=1===j.raw.series.length?{x:n.x,y:n.y}:b.polarToCartesian(n.x,n.y,h,l+(p-l)/2);var A;A=j.normalized.labels&&!b.isFalseyButZero(j.normalized.labels[f])?j.normalized.labels[f]:j.normalized.series[f];var B=a.labelInterpolationFnc(A,f);if(B||0===B){var C=d.elem("text",{dx:z.x,dy:z.y,"text-anchor":c(n,z,a.labelDirection)},a.classNames.label).text(""+B);this.eventEmitter.emit("draw",{type:"label",index:f,group:d,element:C,text:""+B,x:z.x,y:z.y})}}l=p}}.bind(this)),this.eventEmitter.emit("created",{chartRect:e,svg:this.svg,options:a})}function e(a,c,d,e){b.Pie["super"].constructor.call(this,a,c,f,b.extend({},f,d),e)}var f=(a.window,a.document,{width:void 0,height:void 0,chartPadding:5,classNames:{chartPie:"ct-chart-pie",chartDonut:"ct-chart-donut",series:"ct-series",slicePie:"ct-slice-pie",sliceDonut:"ct-slice-donut",sliceDonutSolid:"ct-slice-donut-solid",label:"ct-label"},startAngle:0,total:void 0,donut:!1,donutSolid:!1,donutWidth:60,showLabel:!0,labelOffset:0,labelPosition:"inside",labelInterpolationFnc:b.noop,labelDirection:"neutral",reverseData:!1,ignoreEmptyValues:!1});b.Pie=b.Base.extend({constructor:e,createChart:d,determineAnchorPosition:c})}(this||global,a),a});
//# sourceMappingURL=chartist.min.js.map
/*-------chartlist */
.ct-double-octave:after,.ct-golden-section:after,.ct-major-eleventh:after,.ct-major-second:after,.ct-major-seventh:after,.ct-major-sixth:after,.ct-major-tenth:after,.ct-major-third:after,.ct-major-twelfth:after,.ct-minor-second:after,.ct-minor-seventh:after,.ct-minor-sixth:after,.ct-minor-third:after,.ct-octave:after,.ct-perfect-fifth:after,.ct-perfect-fourth:after,.ct-square:after{content:"";clear:both}.ct-label{fill:rgba(0,0,0,.4);color:rgba(0,0,0,.4);font-size:.75rem;line-height:1}.ct-chart-bar .ct-label,.ct-chart-line .ct-label{display:block;display:-webkit-box;display:-moz-box;display:-ms-flexbox;display:-webkit-flex;display:flex}.ct-chart-donut .ct-label,.ct-chart-pie .ct-label{dominant-baseline:central}.ct-label.ct-horizontal.ct-start{-webkit-box-align:flex-end;-webkit-align-items:flex-end;-ms-flex-align:flex-end;align-items:flex-end;-webkit-box-pack:flex-start;-webkit-justify-content:flex-start;-ms-flex-pack:flex-start;justify-content:flex-start;text-align:left;text-anchor:start}.ct-label.ct-horizontal.ct-end{-webkit-box-align:flex-start;-webkit-align-items:flex-start;-ms-flex-align:flex-start;align-items:flex-start;-webkit-box-pack:flex-start;-webkit-justify-content:flex-start;-ms-flex-pack:flex-start;justify-content:flex-start;text-align:left;text-anchor:start}.ct-label.ct-vertical.ct-start{-webkit-box-align:flex-end;-webkit-align-items:flex-end;-ms-flex-align:flex-end;align-items:flex-end;-webkit-box-pack:flex-end;-webkit-justify-content:flex-end;-ms-flex-pack:flex-end;justify-content:flex-end;text-align:right;text-anchor:end}.ct-label.ct-vertical.ct-end{-webkit-box-align:flex-end;-webkit-align-items:flex-end;-ms-flex-align:flex-end;align-items:flex-end;-webkit-box-pack:flex-start;-webkit-justify-content:flex-start;-ms-flex-pack:flex-start;justify-content:flex-start;text-align:left;text-anchor:start}.ct-chart-bar .ct-label.ct-horizontal.ct-start{-webkit-box-align:flex-end;-webkit-align-items:flex-end;-ms-flex-align:flex-end;align-items:flex-end;-webkit-box-pack:center;-webkit-justify-content:center;-ms-flex-pack:center;justify-content:center;text-align:center;text-anchor:start}.ct-chart-bar .ct-label.ct-horizontal.ct-end{-webkit-box-align:flex-start;-webkit-align-items:flex-start;-ms-flex-align:flex-start;align-items:flex-start;-webkit-box-pack:center;-webkit-justify-content:center;-ms-flex-pack:center;justify-content:center;text-align:center;text-anchor:start}.ct-chart-bar.ct-horizontal-bars .ct-label.ct-horizontal.ct-start{-webkit-box-align:flex-end;-webkit-align-items:flex-end;-ms-flex-align:flex-end;align-items:flex-end;-webkit-box-pack:flex-start;-webkit-justify-content:flex-start;-ms-flex-pack:flex-start;justify-content:flex-start;text-align:left;text-anchor:start}.ct-chart-bar.ct-horizontal-bars .ct-label.ct-horizontal.ct-end{-webkit-box-align:flex-start;-webkit-align-items:flex-start;-ms-flex-align:flex-start;align-items:flex-start;-webkit-box-pack:flex-start;-webkit-justify-content:flex-start;-ms-flex-pack:flex-start;justify-content:flex-start;text-align:left;text-anchor:start}.ct-chart-bar.ct-horizontal-bars .ct-label.ct-vertical.ct-start{-webkit-box-align:center;-webkit-align-items:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:flex-end;-webkit-justify-content:flex-end;-ms-flex-pack:flex-end;justify-content:flex-end;text-align:right;text-anchor:end}.ct-chart-bar.ct-horizontal-bars .ct-label.ct-vertical.ct-end{-webkit-box-align:center;-webkit-align-items:center;-ms-flex-align:center;align-items:center;-webkit-box-pack:flex-start;-webkit-justify-content:flex-start;-ms-flex-pack:flex-start;justify-content:flex-start;text-align:left;text-anchor:end}.ct-grid{stroke:rgba(0,0,0,.2);stroke-width:1px;stroke-dasharray:2px}.ct-grid-background{fill:none}.ct-point{stroke-width:10px;stroke-linecap:round}.ct-line{fill:none;stroke-width:4px}.ct-area{stroke:none;fill-opacity:.1}.ct-bar{fill:none;stroke-width:10px}.ct-slice-donut{fill:none;stroke-width:60px}.ct-series-a .ct-bar,.ct-series-a .ct-line,.ct-series-a .ct-point,.ct-series-a .ct-slice-donut{stroke:#d70206}.ct-series-a .ct-area,.ct-series-a .ct-slice-donut-solid,.ct-series-a .ct-slice-pie{fill:#d70206}.ct-series-b .ct-bar,.ct-series-b .ct-line,.ct-series-b .ct-point,.ct-series-b .ct-slice-donut{stroke:#f05b4f}.ct-series-b .ct-area,.ct-series-b .ct-slice-donut-solid,.ct-series-b .ct-slice-pie{fill:#f05b4f}.ct-series-c .ct-bar,.ct-series-c .ct-line,.ct-series-c .ct-point,.ct-series-c .ct-slice-donut{stroke:#f4c63d}.ct-series-c .ct-area,.ct-series-c .ct-slice-donut-solid,.ct-series-c .ct-slice-pie{fill:#f4c63d}.ct-series-d .ct-bar,.ct-series-d .ct-line,.ct-series-d .ct-point,.ct-series-d .ct-slice-donut{stroke:#d17905}.ct-series-d .ct-area,.ct-series-d .ct-slice-donut-solid,.ct-series-d .ct-slice-pie{fill:#d17905}.ct-series-e .ct-bar,.ct-series-e .ct-line,.ct-series-e .ct-point,.ct-series-e .ct-slice-donut{stroke:#453d3f}.ct-series-e .ct-area,.ct-series-e .ct-slice-donut-solid,.ct-series-e .ct-slice-pie{fill:#453d3f}.ct-series-f .ct-bar,.ct-series-f .ct-line,.ct-series-f .ct-point,.ct-series-f .ct-slice-donut{stroke:#59922b}.ct-series-f .ct-area,.ct-series-f .ct-slice-donut-solid,.ct-series-f .ct-slice-pie{fill:#59922b}.ct-series-g .ct-bar,.ct-series-g .ct-line,.ct-series-g .ct-point,.ct-series-g .ct-slice-donut{stroke:#0544d3}.ct-series-g .ct-area,.ct-series-g .ct-slice-donut-solid,.ct-series-g .ct-slice-pie{fill:#0544d3}.ct-series-h .ct-bar,.ct-series-h .ct-line,.ct-series-h .ct-point,.ct-series-h .ct-slice-donut{stroke:#6b0392}.ct-series-h .ct-area,.ct-series-h .ct-slice-donut-solid,.ct-series-h .ct-slice-pie{fill:#6b0392}.ct-series-i .ct-bar,.ct-series-i .ct-line,.ct-series-i .ct-point,.ct-series-i .ct-slice-donut{stroke:#f05b4f}.ct-series-i .ct-area,.ct-series-i .ct-slice-donut-solid,.ct-series-i .ct-slice-pie{fill:#f05b4f}.ct-series-j .ct-bar,.ct-series-j .ct-line,.ct-series-j .ct-point,.ct-series-j .ct-slice-donut{stroke:#dda458}.ct-series-j .ct-area,.ct-series-j .ct-slice-donut-solid,.ct-series-j .ct-slice-pie{fill:#dda458}.ct-series-k .ct-bar,.ct-series-k .ct-line,.ct-series-k .ct-point,.ct-series-k .ct-slice-donut{stroke:#eacf7d}.ct-series-k .ct-area,.ct-series-k .ct-slice-donut-solid,.ct-series-k .ct-slice-pie{fill:#eacf7d}.ct-series-l .ct-bar,.ct-series-l .ct-line,.ct-series-l .ct-point,.ct-series-l .ct-slice-donut{stroke:#86797d}.ct-series-l .ct-area,.ct-series-l .ct-slice-donut-solid,.ct-series-l .ct-slice-pie{fill:#86797d}.ct-series-m .ct-bar,.ct-series-m .ct-line,.ct-series-m .ct-point,.ct-series-m .ct-slice-donut{stroke:#b2c326}.ct-series-m .ct-area,.ct-series-m .ct-slice-donut-solid,.ct-series-m .ct-slice-pie{fill:#b2c326}.ct-series-n .ct-bar,.ct-series-n .ct-line,.ct-series-n .ct-point,.ct-series-n .ct-slice-donut{stroke:#6188e2}.ct-series-n .ct-area,.ct-series-n .ct-slice-donut-solid,.ct-series-n .ct-slice-pie{fill:#6188e2}.ct-series-o .ct-bar,.ct-series-o .ct-line,.ct-series-o .ct-point,.ct-series-o .ct-slice-donut{stroke:#a748ca}.ct-series-o .ct-area,.ct-series-o .ct-slice-donut-solid,.ct-series-o .ct-slice-pie{fill:#a748ca}.ct-square{display:block;position:relative;width:100%}.ct-square:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:100%}.ct-square:after{display:table}.ct-square>svg{display:block;position:absolute;top:0;left:0}.ct-minor-second{display:block;position:relative;width:100%}.ct-minor-second:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:93.75%}.ct-minor-second:after{display:table}.ct-minor-second>svg{display:block;position:absolute;top:0;left:0}.ct-major-second{display:block;position:relative;width:100%}.ct-major-second:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:88.8888888889%}.ct-major-second:after{display:table}.ct-major-second>svg{display:block;position:absolute;top:0;left:0}.ct-minor-third{display:block;position:relative;width:100%}.ct-minor-third:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:83.3333333333%}.ct-minor-third:after{display:table}.ct-minor-third>svg{display:block;position:absolute;top:0;left:0}.ct-major-third{display:block;position:relative;width:100%}.ct-major-third:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:80%}.ct-major-third:after{display:table}.ct-major-third>svg{display:block;position:absolute;top:0;left:0}.ct-perfect-fourth{display:block;position:relative;width:100%}.ct-perfect-fourth:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:75%}.ct-perfect-fourth:after{display:table}.ct-perfect-fourth>svg{display:block;position:absolute;top:0;left:0}.ct-perfect-fifth{display:block;position:relative;width:100%}.ct-perfect-fifth:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:66.6666666667%}.ct-perfect-fifth:after{display:table}.ct-perfect-fifth>svg{display:block;position:absolute;top:0;left:0}.ct-minor-sixth{display:block;position:relative;width:100%}.ct-minor-sixth:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:62.5%}.ct-minor-sixth:after{display:table}.ct-minor-sixth>svg{display:block;position:absolute;top:0;left:0}.ct-golden-section{display:block;position:relative;width:100%}.ct-golden-section:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:61.804697157%}.ct-golden-section:after{display:table}.ct-golden-section>svg{display:block;position:absolute;top:0;left:0}.ct-major-sixth{display:block;position:relative;width:100%}.ct-major-sixth:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:60%}.ct-major-sixth:after{display:table}.ct-major-sixth>svg{display:block;position:absolute;top:0;left:0}.ct-minor-seventh{display:block;position:relative;width:100%}.ct-minor-seventh:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:56.25%}.ct-minor-seventh:after{display:table}.ct-minor-seventh>svg{display:block;position:absolute;top:0;left:0}.ct-major-seventh{display:block;position:relative;width:100%}.ct-major-seventh:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:53.3333333333%}.ct-major-seventh:after{display:table}.ct-major-seventh>svg{display:block;position:absolute;top:0;left:0}.ct-octave{display:block;position:relative;width:100%}.ct-octave:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:50%}.ct-octave:after{display:table}.ct-octave>svg{display:block;position:absolute;top:0;left:0}.ct-major-tenth{display:block;position:relative;width:100%}.ct-major-tenth:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:40%}.ct-major-tenth:after{display:table}.ct-major-tenth>svg{display:block;position:absolute;top:0;left:0}.ct-major-eleventh{display:block;position:relative;width:100%}.ct-major-eleventh:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:37.5%}.ct-major-eleventh:after{display:table}.ct-major-eleventh>svg{display:block;position:absolute;top:0;left:0}.ct-major-twelfth{display:block;position:relative;width:100%}.ct-major-twelfth:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:33.3333333333%}.ct-major-twelfth:after{display:table}.ct-major-twelfth>svg{display:block;position:absolute;top:0;left:0}.ct-double-octave{display:block;position:relative;width:100%}.ct-double-octave:before{display:block;float:left;content:"";width:0;height:0;padding-bottom:25%}.ct-double-octave:after{display:table}.ct-double-octave>svg{display:block;position:absolute;top:0;left:0}
Here is the render:
SE ECO EXPERT
SE ECO EXPERT
