Mosaic cloud
Is there a way to force the cloud update by script?
Best regards Cristian
Do you mean sync cloud app? Why do you ask?
(12.01.2022, 11:45)Daniel Wrote: Do you mean sync cloud app? Why do you ask?
Yes, because the cloud seems update ( green dot ) on the log visualize connect, but doesn't update and send telegram.
To make the cloud work again I need to press sync on the app and it works again without problems.
It happens always after a power supply failure (main line)
Does the same thing happen if you reboot LM via System config?
(12.01.2022, 11:51)admin Wrote: Does the same thing happen if you reboot LM via System config?
I need to check.
Yes, I have tested and I confirm that it does after a reboot from system config too.
An updated LM cloud app has been published, see if it fixes the issue for you
(14.01.2022, 11:57)admin Wrote: An updated LM cloud app has been published, see if it fixes the issue for you
Thanks I will make tomorrow and I let you know.
