Threads: 40
No, this cannot be customized
Threads: 38
02.02.2022, 08:45
(This post was last modified: 02.02.2022, 12:10 by Mirco.)
ok, another question, is it possible to change a virtual group address in real time, like what happend with the default value of the circular slider, when sliding without release mouse?
and it is possible to do the same with the +/- direct input?
Threads: 40
The value can only be sent on mouse/touch release. This is by design to prevent sending many bus telegrams.
Threads: 38
I know this, the problem is that in the same widget I have the circular slider and the +/- direct input with the same group address. I have hidden one of the 2 vaue and the problem is that if I use one of the 2 that that have it's value hidden, the value of the other one don't change until I release the mouse if I use the slider or if I use the +/- it change only after few seconds
Threads: 40
Yes, this is by design. Direct input has a short delay to prevent sending many telegrams when a user quickly presses +/- buttons.
