Threads: 83
Hello
I want to use the SL as EIBnet, and i have ip router as backbone and line couplers for the sub lines.
What should i set the mode of the SL.
Also if I set the mode to IP Tunneling i should enter a Tunneling router ip, what is this ip?
Best Regards,
Threads: 31
What do you mean by EIBnet? LM talks by default KNX routing(multicast) in this case you can use TP-UART when KNX TP is connected or IP Routing when only on IP. Tunneling can be used if you want LM to connect via Tunneling to another IP router. Only one can be connected.
Threads: 31
You can use KNX TP only when TP uart mode is selected
Threads: 31
ETS you can use in TP-uart and IP Routing but it routing you will only see telegrams on IP.
Threads: 83
Thanks Daniel
So inorder to download from ETS I should use TP-UART. then I could switch the mode to IP routing.
Best Regards,
Threads: 31
Tp uatr mode use both, routing and tp. No need to change.
Threads: 83
16.02.2022, 12:00
(This post was last modified: 16.02.2022, 13:38 by khalil.)
Thanks and appreciate your help.
If you could reference a document for more details I will be thankful.
I use the SL as TP-UART.
but when I try to connect ETS to SL locally I cant connect unless enabling NAT, and when I try to download devises application I got this message:
The bus connection KnxIpTunneling : ***Project_Name*** - no nat - 192.168.10.10:3671 of the line 1.1 Line-1 could not be established.
The interface is not reachable.
While I can bing to line 1.1 IP Router from SL.
any idea?
Edit: Its IT issue
Best Regards,
