Threads: 107
Hi there,
it seems that with the new firmware there is only a Mosaic instance. I have 3 users and everyone has his Mosaic instance.
If I update to the new firmware I lost this opportunity?
Thank you for your help.
User access has been implemented in Mosaic. You can now use one instance for multiple users.
Threads: 31
In LM user access, same place like for custom visu.
Threads: 31
The import is not possible. The only you can do it to export custom widgets to files and import back.
The url will be the same only different user should have different access level. You should make one big Mosaic project and assign permissions per user.
You can keep using old Mosaic with Instance but there won't be any update to it.
Threads: 31
Can you give some more info about the panel? OS and version. What do you use to display mosaic and versions.
Threads: 31
Can you display any other app?
Threads: 31
Did you try using direct url to other apps?
Threads: 31
Do you have password for apps enabled?
Threads: 31
Enable password and try putting user and password in to the url. It might work if it is old enough.
Threads: 31
It seems browser does not allow simpe auth and it also blocking popup request for credentials.
I see no other option to disable password for apps but this is not recommended due to zero security.
I can send you the Mosaic instances so you can use it on LM if you want but this will be the old version last available on the store.
