Mimicing a kWh meter
I searched but no luck. Anyone experience with mimicing a kWh meter from Logicmachine RS485 (Slave) to a inverter or Tigo CCA?
I am looking for a way to send the data from the P1 port on a grid power meter (using  https://domoticom.nl/p1g2/) to a inverter or Tigo CCA using the Logic machine as the translation device from KNX to RS485 (saving an extra kWh meter and able to visualize also in logic machine)
If you need modbus slave check this
https://forum.logicmachine.net/showthread.php?tid=181
Thanks for the reply. I will dive into it. Is it also possible to use the Logic Machine as both Modbus TCP master and slave at the same time? (as in let the Tigo CCA read out the datapoints from the Logic Machine in Modbus TCP)
Yes, both modes can be used at the same time.
