Threads: 11
Hi!
When using datatype 3.byte time/day in visualization.
I want to set a time when pressing the time in visualization, but there u can also set day and seconds.
Is it possible to hide seconds and day options?
So its only hour and minutes you can set?
Or if there is a better way to do it?
-s-
Threads: 8
(22.03.2022, 14:36)admin Wrote: Add this to Custom CSS:
.timepicker-day,
.timepicker-second {
display: none;
.timepicker {
margin: 10px 0;
display: flex;
justify-content: space-evenly;
I hoped to use this 'conditionally', so only on certain timepickers with an additional class,
but embedding this code in a construct like .hourMinPick {...} does not work. HOw should that be written?
Don't ask what we can do in KNX but wonder what we can't - www.KNXlogic.eu
Which firmware version do you have?
Threads: 17
16.06.2022, 08:52
(This post was last modified: 16.06.2022, 09:27 by JRP.)
Hello
Wiser, 2.7.0
By the way css without additional classes doesn't work for me either.
What I have in an object on the display set to Display Mode as Value.
Greeatings
This CSS only hides the second input field when changing the value. The displayed value is still in H:MM:SS format. Options to hide seconds and day from both control and display will be added in the next firmware release.
Threads: 17
Ok, I'll wait for the next update then.
Thank you
