Background color depends on the Value
Hello Guys,
Please, I hope you could help me with that, I have no knowledge with Java or CSS
I want to change the background color of Temp Value depending on the Value itself, for example, if the Value is >= 25 then the background color should be Red if it is between 21 and 24.5 then orange and if it's below then blue.
Many thanks in advance
See this: https://forum.logicmachine.net/showthrea...2#pid20292
I am not sure if it 100% relevant for your question but it works fine for my setup giving different background colors related to values.
I use the Object "Additional icons" button where you can specify different values and assign corresponding PNGs to it. So I have pre-made some few PNGs in different colors which will change on different values. Very simple setup.
