21.04.2022, 18:37
		I have a waterguard which have sensors that shuts off the main valve into the house in case of a water leak. This unit also have alarm relay outputs which is not more than NO or NC switches. So when there is a leak the NC or NO switches changes state.
I want to use this to control a KNX actuator and was thinking that I could use my LM Reactor v3 to do this.
The question is how do I do this? Do I need a pull up/down resistor of some sort on the input? Digital or analog? And how do I set it up in the reactor?
