Visualization, Pin code after wakeup
Hello
Is it possible to somehow to get it to ask pin code after device has been inactive for x minutes in visualization. Like you can set it to dim and on wake up it would ask for pincode after that time
Enable "Visualization pin code" in User access settings. Add this to Custom JavaScript. Inactivity timeout is 60 seconds, adjust as needed.
$(function() {
  var timeout = 60 * 1000;
  var oldfn = $.stopEvent;
  function ontimeout() {
    window.location = '/scada-vis/pin?return=index';
  $.stopEvent = function(event) {
    clearTimeout(timer);
    timer = setTimeout(ontimeout, timeout);
    return oldfn(event);
Thanks, Works Smile
