26.05.2022, 15:10
Can I make a slider switch like this in Visualization? Or something Similar.
The slider switch work as follow:
- Slide the button to change 8-16 bit object value (dimming or temperature)
- We can tap to the button to turn on/off 1 bit object
- When the 1 bit object was on, the slider background color is brown, otherwise it is gray as in screenshot.
Thank you
![[Image: dfNmuUw.png]](https://i.imgur.com/dfNmuUw.png)
Thank you
![[Image: DCxzXkK.png]](https://i.imgur.com/DCxzXkK.png)
