Creating a KNx point for Modbus Device Communication Error Situation
Hello ,
When we have a communication problem in Logic Machine, In modbus section of LM, modbus device turns red color and we can understand there is a communication problem. I would like to transfer this information as a Bacnet point but I need first , I need to transfer this communication failure in to KNX data point.
How could i do that ?
Regards,
Hi Savaskorkmaz,
I don't know if there is a function for this in the system, but i solved it once with a little resident script.
Put your actions on the position where the logging is now (replace them with your action).
123456789101112131415161718192021
-- Check all modbus meters for connection query = 'SELECT * FROM modbus_devices' meter_state = db:getall(query) previous_state = storage.get('meterstate') if previous_state == nil then  for _, device in ipairs(meter_state) do    if device.active == 0 then      log(device.name .. " = down")    else      log(device.name .. " = active")    end  end  storage.set('meterstate', meter_state) else  for _, device in ipairs(meter_state) do    if device.active ~= previous_state[_].active then      log(device.name .. ' is changed to ' .. device.active)    end      end  storage.set('meterstate', meter_state) end
Erwin van der Zwart
For now Erwin's script is the only solution, but we have this feature in our to-do list Smile
Here is a version with writing to KNX objects:
12345678910111213141516171819202122232425262728293031323334
-- Check all modbus meters for connection -- Function to send changes to KNX function writetoknx(name,active)     if name == 'Meter 1' then  -- name must match modbus device name    grp.write('1/1/1', toboolean(active))  elseif name == 'Meter 2' then    grp.write('1/1/2', toboolean(active))  elseif name == 'Meter 3' then    grp.write('1/1/3', toboolean(active))  elseif name == 'Meter 4' then    grp.write('1/1/4', toboolean(active))  elseif name == 'Meter 5' then    grp.write('1/1/5', toboolean(active))  end end -- Get meter status query = 'SELECT * FROM modbus_devices' meter_state = db:getall(query) previous_state = storage.get('meterstate') if previous_state == nil then  for _, device in ipairs(meter_state) do      writetoknx(device.name,device.active)  end  storage.set('meterstate', meter_state) else  for _, device in ipairs(meter_state) do    if device.active ~= previous_state[_].active then         writetoknx(device.name,device.active)    end      end  storage.set('meterstate', meter_state) end
