4 byte
Hi at all,
There is a way to insert 4 byte value in the mosaic custom object signed in the attached file?
Best regards Cristian
Do you mean that the control does not fit all digits for a 4-byte data type?
Control width can be changed via Custom CSS in Settings & themes:
#setting_custom_widget [data-element] .number,
.widget-custom .number {
  width: 130px;
(07.07.2022, 08:56)admin Wrote: Do you mean that the control does not fit all digits for a 4-byte data type?
  width: 130px;
Ok I will check
Thanks so much
  width: 130px;
Ok it works.
Thank you so much
