SONOS app
Daniel, is there a current permanent fix that would restore my Sonos script? Or do we have to wait until the Sonos Logic Machine application will be updated by its developer?
I was so happy with it, then suddenly it has stopped working...
(01.05.2019, 22:18)andeug Wrote: Daniel, is there a current permanent fix that would restore my Sonos script? Or do we have to wait until the Sonos Logic Machine application will be updated by its developer?
This new Sonos APP is totally different from old one.  This APP was tested and approve by the SONOS itself and they were against all the custom functionality the previous app did. You have 2 options:
1. Use new app and old libraries, just change location of them in your script.
2. Use old app, I can provide you the link.  By using the old app you take a risk that it might stop working one day if sonos block old API. Nobody knows if this happen and when.
And where I can find your new Sonos app API?
It is not ours, it is SONOS
https://developer.sonos.com/build/direct-control/
(24.05.2019, 09:04)Daniel. Wrote: It is not ours, it is SONOS
hi again Daniel,
After the new version of Sonos App, my LM5 objects (4/1/1, ...) do not work any more.  Basically I cannot communicate with Sonos from the LM5 scripts, commands, etc.  I read in the articles that I have to upload old sonos.lua and sonos.lp to the/user directory.  Is that the right solution? If yes, I also appreciate the instruction/guide on how to do that.  I've never done this and I don't even know how to FTP it.  Any referral to the right direction will be highy appreciated.
Many thanks,
Kam
Enable FTP server and set password for apps user in System config > Services > FTP Server
Connect via regular FTP client using apps user and copy both files to user directory there
Change path in your scripts to /user/sonos.lp instead of /apps/data/sonos/sonos.lp
And if you don't succeed here is old app
https://boards.wetransfer.com/board/st5k...939/latest
(13.06.2019, 13:00)admin Wrote: Enable FTP server and set password for apps user in System config > Services > FTP Server
Worked like a charm.  Many thanks.
(13.06.2019, 13:02)Daniel. Wrote: And if you don't succeed here is old app
One more question:The new Sonos App automatically created all the new group addresses and assigned them to each widget.  However, when I change the control of one room (in Mosaic or directly on the control object), it does it for ALL the rooms at the same time, eg, if I pause a song in one room, it stops in all the rooms.  Is this an issue related to Sonos or LM?
If I can't fix this I may have to switch back to the old Sonos app that you have already sent me.
Thanks,
Kam
Thanks,
Kam
Hm, didn't you group them by any chance? I don't have more than one player to test it. I asked app developer to check and they will do it next week.
Thanks,
Kam
I did both grouping and un-grouping with the same result.  Thanks for checking with the app dev. team and I look forward to learning the response and have a nice weekend.
Kam
Is there a way to manually define the IP address of SONOS speakers?
I have them in a different VLAN than the LM4 and the app can not find them.
Thank you for your help!
Is there any way to change the color of the Sonos app? The green and white does not look very good to my black visualizationSmile
BR Even Sundgot.
