SONOS app
That’s not the api of the Sonos app, but yes that will work fine (:
Hello everyone,
I'm not sure if this post is here, but I hope to help someone, because I didn´t see this information in the forum, to control SONOS Play Mode and very important (for me) the Sleep function.
upnpavcmd('*IP*', 1400, 'SetPlayMode', '<NewPlayMode>*The Play mode desired*</NewPlayMode>')
the differents Play Modes are: NORMAL, REPEAT_ALL, SHUFFLE_NOREPEAT, SHUFFLE (with repeat All)
The Sleep Function:
upnpavcmd(*IP*, 1400, 'ConfigureSleepTimer', '<NewSleepTimerDuration>00:00:00</NewSleepTimerDuration>')
Best Regards.
What is the progress on the new Sonos App?
Mr.D
Still in development, no ETA yet..
The app is finished only now Sonos has to certify it. They need controller and the app to test it.
Is that how it works with the new Sonos API? They have to physically validate all equipment that uses their API? If so, that’s slightly insane..
(17.10.2018, 09:31)FatMax Wrote: Is that how it works with the new Sonos API? They have to physically validate all equipment that uses their API? If so, that’s slightly insane..
YES, Sonos want to control everything.
Hi Daniel,
Why they cannot just buy a controller to perform their tests ? It is very strange !
B.R,
Chouaibou.
What so strange on a certification path? I think it’s more then normal that Sonos has build a API and allows only certified hardware and software to use the API to protect it from uncontrolled connections.
So yes that means a certification path on apps and devices but you see this everywhere.
