23.07.2018, 21:33
That’s not the api of the Sonos app, but yes that will work fine (:
SONOS app
23.07.2018, 21:33
That’s not the api of the Sonos app, but yes that will work fine (: BR, Erwin
06.08.2018, 12:10
Hello everyone,
I'm not sure if this post is here, but I hope to help someone, because I didn´t see this information in the forum, to control SONOS Play Mode and very important (for me) the Sleep function. upnpavcmd('*IP*', 1400, 'SetPlayMode', '<NewPlayMode>*The Play mode desired*</NewPlayMode>') the differents Play Modes are: NORMAL, REPEAT_ALL, SHUFFLE_NOREPEAT, SHUFFLE (with repeat All) The Sleep Function: upnpavcmd(*IP*, 1400, 'ConfigureSleepTimer', '<NewSleepTimerDuration>00:00:00</NewSleepTimerDuration>') Best Regards.
16.10.2018, 21:34
(This post was last modified: 16.10.2018, 21:34 by Erwin van der Zwart.)
Still in development, no ETA yet.. BR, Erwin
17.10.2018, 07:10
The app is finished only now Sonos has to certify it. They need controller and the app to test it.
17.10.2018, 09:31
Is that how it works with the new Sonos API? They have to physically validate all equipment that uses their API? If so, that’s slightly insane..
17.10.2018, 09:43
20.10.2018, 06:04
(17.10.2018, 09:43)Daniel. Wrote:(17.10.2018, 09:31)FatMax Wrote: Is that how it works with the new Sonos API? They have to physically validate all equipment that uses their API? If so, that’s slightly insane.. Hi Daniel, Why they cannot just buy a controller to perform their tests ? It is very strange ! B.R, Chouaibou.
20.10.2018, 07:23
What so strange on a certification path? I think it’s more then normal that Sonos has build a API and allows only certified hardware and software to use the API to protect it from uncontrolled connections. So yes that means a certification path on apps and devices but you see this everywhere. BR, Erwin (20.10.2018, 07:23)Erwin van der Zwart Wrote: Hi, Hi Erwin, Thank you for your clarification. There are more and more open sources, sometimes we forget proprietary API requirements. B.R, Chouaibou.
Hei Daniel,
Is there a ETA on the approval? Are we talking about this year, or 1st quarter next year?
Mr.D
01.11.2018, 18:48
Nobody knows.
05.02.2019, 18:39
Mr.D
05.02.2019, 19:12
(This post was last modified: 05.02.2019, 19:12 by Erwin van der Zwart.)
I know we passed certification, should not take long anymore..
Erwin |
