SONOS app
Unfortunately there is no such option in this version. You can play specific playlist if that will be your door bell. As alternative you can still use it old way only you have to upload old libraries manually. It was explained here earlier.
>-- play playlist by ID
>sonos_app.SendApiActionCommand(url_group_id, 'playPlaylist', playlist_id)
How can I play, a playlist with repeat?
To set Repeat try this
-- set volume
sonos_app.SendApiActionCommand(url_group_id, 'setPlayModes', 'repeat')
Not tested so might not work.  Instead repeat also try ['repeat']  other options for 'setPlayModes' are:
  • repeatOne
  • crossfade
  • shuffle
It does not work.. :-(
You can just add the player to group and then create widget in Mosaic, after that all the control objects will be created. Repeat will be one of them. I will check this once back to office after the brake.
Is there a command for controlling one single planer? I am only finding groups, but my customer are regrouping all the time, so working with groups will not be so good.
No such thing in the current API, You can still use old one. It was explained here how to do it.
(01.08.2019, 06:18)admin Wrote: You are probably missing user/sonos.lua file. Have you uploaded both files (sonos.lp and sonos.lua) to FTP?
I am trying this as well, and get the same error. I have uploaded both the files to /user.
I got the files from post #83, but maybe there is something wrong in one of them? Is there another place I can dowload the two files?
Or maybe I have another problem?
The code I have is;
require('json')
require('socket.http')
reply = socket.http.request('http://admin:password@192.168.1.9/user/sonos.lp?action=getsonosdata')
Do you mean this?
https://forum.logicmachine.net/showthrea...1#pid12301
(13.01.2020, 11:53)Daniel. Wrote: Do you mean this?
Yep, thx
There must have been something wrong with the one I had, because now it seems to work.
Yep, thx
OK, so now the connection seem to work, but I am not able to play a file. I have found a code for this, but so far nothing happens.
What I have is;
-- Load modules
-- Set timout
socket.http.TIMEOUT = 5
reply = socket.http.request('http://admin:hoyemknx@127.0.0.1/user/sonos.lp?action=getextendedstate&uuid=RINCON_7828CAF5CEC201400&createbaseimg=false')
log(reply)
audiofile = socket.url.escape('http://127.0.0.1/user/Ringeklokke.mp3')
reply = socket.http.request('http://admin:hoyemknx@127.0.0.1/user/sonos.lp?action=say&name=Kjøkken&audiofile=' .. audiofile .. '&volume=30&duration=55')
log(reply)
The logs I get from this is;
1. * string: {"TrackIndex":1,"Playmode":"NORMAL","Crossfade":0,"Repeat":false,"PlayingTime":"0.... - So this seems OK
2. * nil
Any ideas?
