Threads: 78
10.08.2022, 16:43
(This post was last modified: 10.08.2022, 16:45 by CristianAgata.)
Hi Edgars,
This sounds good,
My clients usually doesn't like the connection to the server.
In auto connection there is several problems.
If I'm under my wi-fi (net where there's the LM) it works fine. If I'm not under my wi-fi (another net in example under a public wi-fi) it doesn't work and shows only a black screen.
Second. At the moment it is possible add more server but the remote connection it is one for all. Many clients have more servers, if all are connected to cloud there's no problem, but if one is on the cloud and the other no, there is a issue.
Anyway I 'm picking up the opinion of my Italian users and the next days I will give you the feedback.
Best regards and thanks again for the team job.
Threads: 106
Hi Edgars,
IOS Android APP need fullscreen option. There is some arrow and useless blank area in the app which is very ugly. You can put some 3 almost transparent dots to turn back menu etc.
Threads: 30
Totally agree, plus (as ChristianAgata said) it's not working fine sometimes, for example with VPN and if you're not using cloud.
Thanks for asking us, much appreciated.
Threads: 4
26.08.2022, 11:21
(This post was last modified: 26.08.2022, 11:21 by suporte.arqtech.)
Auto switchover between connections. As well as many other users, I'm using only the "tablet/PC" visualization for local and remote connection. For that, it would be very handly if I could specify some wifi SSIDs in wich local access is needed. When I'm not connected to these specific SSIDs the app shows the VPN connection instead of an error message...
Threads: 87
I think would be good to implement ZeroTier connection there. If app is planned to switch between devices - automatical switching between ZeroTier networks for remote connection interesting. Also device status online/offline - how long for connection errors control, if it possible from ZeroTier API.
Alex
Threads: 68
Hi, are there any news about the new app?
Threads: 101
Sending critical IOS messages
Threads: 12
+1 !
Cloud Mosaic auto-loading would be fantastic too.
