Custom value select: not work?
I am developing my own graphic for a heating system.
I set "visualisation parameter" of 2 byte object to "custom value select". As shown in the example, I cannot understand the reason why I cannot insert the value using keyboard.
What's wrong please?
For Custom value select to work you need to define Custom values first. If you want to input the value directly you need to use "Direct input / Step +/-" mode.
