Visualitzation access
Is there any way to have an access to a public visualitzation (read-only) without user neither password, and when login using username + password have acces to the same pages but with write permissions?
We need it for an application where temperature/status/... values should be seen for anyone from a webpage, but setpoints, ... only modified by loged users
You can only disable password access for visualization completely but it will still be read/write. The only solution I see is to create a custom HTML/Lua page (.lp) with values and place it into public directory via FTP. This won't require password for access. Unfortunately it's more or less double work.
Ok, I'll try... Thanks!
