Custom Javascript - simple Hello World example?
Hi!
I cannot get the "Custom Javascript" tool to function in Wiser for KNX from the menu Scripting > Tools > Edit custom JavaScript
This is the default content of the textfield:
$(function(){
  // your code here
Exactly what should I input here to make the js-code run in the web browser when using the Touch3 visualization?
I've tried replacing //your code here with console.log('Hello world') but the browser console reports nothing. Nor does log('Hello world in W4K') log anything to the Wiser for KNX "Logs"...
NB. I have mailed Schneider support (who usually respond within a week) but for two weeks I've received no answer...
Thanks!
Robert
Custom JS only works in standard visualization, trends and schedulers.
Aha! I see.
Is there any other method to inject Javascript into a Touch3 visualization in Wiser for KNX? Ideally as a separate .js-file.
Would it be possible to access the template files for the Touch3 viz and add something like <script src="/path/my-javascript.js"></script> and then update this referenced file occasionally?
There's no easy way of doing this. What kind of functionality do you want to implement with custom JavaScript?
I was planning on doing all sorts of things. For example modifying CSS (=styles) and the DOM (=HTML elements), parsing JSON strings to draw simple diagrams, adding tooltips etc. Basically things too complex to maintain unless they can be stored in an external .js-file...
LM Mosaic supports custom JS/CSS widgets but SE Touch3 does not. There's nothing that we can do about it.
