Threads: 5
Hi everyone, can you share the ZeroTier package v. 1.10.1 to install into LM5 Lite (i.MX6) SW: 20220922 ?
I've uninstalled it to reset my zt network but i do not have the file to reinstall it. I've tryed with v. 1.8 but it seems it's not accepted.
Thanks everyone for the support
Threads: 5
It worked, thanks for the fast support
Newer firmwares have fw images and packages digitally signed. Sig file is used to verify the file integrity. It's not needed on older firmwares.
Why do you need to update ZeroTier? Older versions should work.
2022 firmwares which are not published yet.
Threads: 86
If I clearly understood, I can just install newer ZeroTier package at my LM devices? I see I have 1.6.5 version installed. After upgrade, all other params will not be changed?
Alex
ZeroTier is built into the firmware. You don't need to install anything.
