ZeroTier img
Hi everyone, can you share the ZeroTier package v. 1.10.1 to install into LM5 Lite (i.MX6)  SW: 20220922 ?
I've uninstalled it to reset my zt network but i do not have the file to reinstall it. I've tryed with v. 1.8 but it seems it's not accepted.
Thanks everyone for the support
Try this:
https://dl.openrb.com/pkg/zerotier_1.10.2-1_imx6.ipk
https://dl.openrb.com/pkg/zerotier_1.10.2-1_imx6.sig
It worked, thanks for the fast support
(10.11.2022, 08:44)admin Wrote: Try this:
Hello Admin,
What is .sig file for?
I understand that if we need to update Zerotier in LM we uninstall the old version then add package via System/Packages the .ipk file.
Regards
Newer firmwares have fw images and packages digitally signed. Sig file is used to verify the file integrity. It's not needed on older firmwares.
Why do you need to update ZeroTier? Older versions should work.
(29.11.2022, 12:14)admin Wrote: Newer firmwares have fw images and packages digitally signed. Sig file is used to verify the file integrity. It's not needed on older firmwares.
No specific reason just to have same version on LM as Windows client.
Which FW version is this sig needed for because I just did a test updating the package on one LM running FW 20211215 and worked fine without .sig needed.
Thank you for your quick reply and clarification.
2022 firmwares which are not published yet.
If I clearly understood, I can just install newer ZeroTier package at my LM devices? I see I have 1.6.5 version installed. After upgrade, all other params will not be changed?
Alex
ZeroTier is built into the firmware. You don't need to install anything.
OK,
thank you!
