LM 5 Lite not connecting to Internet
Hi!
I am facing a problem on a new LM 5 Lite , that cannot connect to the Internet for some reason.
I am trying to download new Applications but I am receiving the message I am posting .The firewall of the modem /router is disabled. I can ping 8.8.8.8 and 8.8.4.4 but no connection for LM. I have also Internet on my PC .
What is the problem with the connection?
Thank you in advance
BR.
Try a different DNS - 1.1.1.1 or 192.168.1.1 if your router has a DNS server. Can you ping 157.90.169.227 and openrb.com from LM?
I tried different DNS servers but without luck
How I am going to ping this address?
System config > Status > Network utilities
(22.11.2022, 12:50)admin Wrote: System config > Status > Network utilities
These are the results for pinging the specific address
Ok, but what happens if you ping a domain name (openrb.com) instead of an IP address?
(22.11.2022, 13:54)admin Wrote: Ok, but what happens if you ping a domain name (openrb.com) instead of an IP address?
This is it
Try rebooting LM.
It didn't worked again. Maybe a hard reset to factory default?
(22.11.2022, 14:10)admin Wrote: Try rebooting LM.
I fixed it only bu changing the IP address from some reason to 192.168.1.200. And now it works
Run this script once and post what you get in Logs tab:
res, err = require('socket.http').request('https://apps-v16-1.logicmachine.net/')
log(res, err)
