custom CSS circularslider
How to change the internal background color in (.popover.control-circularslider)
It's not possible to change it via CSS, but you can set it per-object in Objects tab -> Vis. parameters.
Try this:
.popover.control-circularslider {
  background-color: #F0F;
Don't work
You have to add !important to background color property if you have "Usermode background color" set in Vis. configuration.
  background-color: #F0F !important;
(03.11.2016, 09:16)admin Wrote: You have to add !important to background color property if you have "Usermode background color" set in Vis. configuration.
Its OK!
