Threads: 163
Greetings I have 2 problems with lm5: 1 by scanning line connected with usb adapter I see all devices, using lm as interface no. 2 visualization with visu works correctly while with mosaic it doesn't, I can control the devices but then if I go out and come back in the status does not correspond to reality. what can i check Thank you
Threads: 31
Seems to me like LM is busy. Check if it is not overloaded and also bus traffic. When you see not correct status values check objects in LM if they have correct values.
For Mosaic issue try installing 2022 RC1 firmware and the updating Mosaic to the latest version.
Threads: 31
Try downloading it again, sometimes file is corrupted.
How many KNX devices do you have on the line? Can you record group monitor in ETS while doing the scan and send it to us?
