04.01.2023, 20:11
Hello our clients is missing very needed feature.
Can be please in next firmware release implemented in schedullers not only sunset, sunrise or time, event but feature when you can select GA and set value (<,>, =, =<, =>) of that GA like event?
For example when Outdoor LUX is 100 then set value light in schedled light on....
Now it is very hard to make good cycle script which will check client inserted value in visualization every (for example) 5min than make some action on desired GA. After that i need to disable this script for client override option.... and enable script in some time again.
Thank you.
Thank you.
