Threads: 58
Hi all,
I'm scripting a process to simulate power meters with luamodbus functions, and it works wery well when I read all my registers with ModbusPoll scanner.
But using my script with a real Modbus master product, I have a lot of "connexion errors" (printed by the master).
@IP, port and slaveId are corrects...
Any idea about this ?
Thank's in advance.
All my best.
Dominique
Threads: 31
Which script do you use?
Threads: 58
(17.01.2023, 12:55)Daniel Wrote: Which script do you use?
Code: --------------------------------------------------------------------------------
-- Wiser For Knx : Modbus esclave TCP/IP
-- Simulateur de centrale de mesure pour EcoStruxure EV Charging Expert
-- Modèle : iEM3x5x pour Bornes de recharge PRO AC
-- v1.2 du 17/01/2023 - D.Barboyon
-- (c) Sigma Tec - 2023
------------- Paramétrage ------------------------------------------------------
idPort = 503 -- No de port Modbus/TCP - toujours >= 502
idSlave = 3 -- No esclave Modbus/TCP - toujours >= 2
PMname = "iEM3155-B2" -- nom du compteur - long <= 14 car
idGroup = idPort-500 -- idGroup/slaveNum/x
idSteMapping1 = 0
idSteMapping2 = 0
idSetMapping3 = 6502
idSteMapping4 = 6502
-- Table des objets Wiser For Knx et registres associés
groupList = {
{ addr = idGroup, datatype="string" , name=PMname ,reg=idPort , unit="" , tags="-"},
{ addr = idGroup, datatype="uint16" , name="I1" ,reg="3000" , unit="A" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="I2" ,reg="3002" , unit="A" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="I3" ,reg="3004" , unit="A" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="P1" ,reg="3054" , unit="kW" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="P2" ,reg="3056" , unit="kW" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="P3" ,reg="3058" , unit="kW" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="P" ,reg="3060" , unit="kW" , tags="modbus"},
{ addr = idGroup, datatype="uint32" , name="ET" ,reg="3204" , unit="kWh" , tags="modbus"},
{ addr = idGroup, datatype="bool" , name="PH1" ,reg="true" , unit="" , tags="-"},
{ addr = idGroup, datatype="bool" , name="PH2" ,reg="true" , unit="" , tags="-"},
{ addr = idGroup, datatype="bool" , name="PH3" ,reg="true" , unit="" , tags="-"},
{ addr = idGroup, datatype="bool" , name="BTN" ,reg="true" , unit="" , tags="-"},
{ addr = idGroup, datatype="unit16" , name="CURSEUR" ,reg="true" , unit="A" , tags="-"},
{ addr = idGroup, datatype="bool" , name="BTN MONO" ,reg="false" , unit="" , tags="-"},
{ addr = idGroup, datatype="bool" , name="BTN TRI" ,reg="true" , unit="" , tags="-"},
{ addr = idGroup, datatype="string" , name="TYPE MONO-TRI" ,reg="TRI" , unit="" , tags="-"},
{ addr = idGroup, datatype="bool" , name="PHASE MONO" ,reg="1" , unit="" , tags="-"},
{ addr = idGroup, datatype="uint16" , name="I Phase AVG" ,reg="3010" , unit="A" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="U Phase1" ,reg="3028" , unit="V" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="U Phase2" ,reg="3030" , unit="V" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="U Phase3" ,reg="3032" , unit="V" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="U AVG" ,reg="3036" , unit="V" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="P apparente" ,reg="3076" , unit="kVA" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="Fact Pu" ,reg="3084" , unit="" , tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="Frequence" ,reg="3110" , unit="Hz" , tags="modbus"},
{ addr = idGroup, datatype="uint32" , name="QT E" ,reg="3220" , unit="kVAR", tags="modbus"},
{ addr = idGroup, datatype="uint16" , name="QT P total" ,reg="3068" , unit="kVAR", tags="modbus"}
-- Spécifique Pro AC : reg Modbus 6501 (uint16) = SlaveId obligatoire
local proacSlaveReg = 6501
-- Gestion de la création des objets Wiser For Knx
function ST_grpCreate(STdatatype,STgroup,STname,STcomment,STunits,STtag)
grp.create({
datatype = STdatatype,
address = STgroup,
name = STname,
comment = STcomment,
units = STunits,
tags = { "EVCE", STname },
-- Scan la table et crée les objets WFK si nécessaire
for i, groupCurr in ipairs(groupList) do
STgroup = groupCurr.addr.."/"..idSlave.."/"..i
if i == 1 then -- spécifique objet "nom de la centrale de mesure"
nomGroupe = groupCurr.reg.."#"..idSlave
valGroupe = groupCurr.name
objGroupe = STgroup
-- Update objet "nom de la centrale de mesure"
grp.write(objGroupe, valGroupe)
if grp.find(STgroup) then
--existe deja
-- crée le groupe
STdatatype = groupCurr.datatype
STname = nomGroupe.."-"..groupCurr.name
STcomment = "-"
STunits = groupCurr.unit
STtag = groupCurr.tags
-- Processus MaJ registres Modbus slave
if not mb then
log("EVCE cyclic - Modbus #2 : starting mb")
require('luamodbus')
-->>>>>>>>>Modbus slave setting<<<<<<<<<<<<<<<<<<<<<<<<
-- Modbus TCP
mb = luamodbus.tcp()
mb:open('0.0.0.0', idPort)
-- slave id
mb:setslave(idSlave)
-- init slave storage for coils, discrete inputs, holding registers and input registers
mb:setmapping(idSetMapping3, idSetMapping2, idSetMapping3, idSetMapping4)
-- >>>>>>>>>>>Coil write callback<<<<<<<<<<<<<<<<<<<<<<
mb:setwritecoilcb(function(coil, value)
if coil == 0 then
grp.write('0/0/12', value, dt.bool)
alert('coil: %d = %s', coil, tostring(value))
end)
-->>>>>>>>>>>Register write callback<<<<<<<<<<<<<<<<<<<
mb:setwriteregistercb(function(register, value)
if register == 0 then
-- send value limited to 0..100
grp.write('0/0/13', math.min(100, value), dt.scale)
alert('register: %d = %d', register, value)
end)
-- spécifique Pro Ac ----------------
addRegister = proacSlaveReg
addRegister = addRegister -1
mb:setregisters(addRegister, idSlave)
log("EVCE cyclic - Modbus #2 : END OF starting mb")
-- Scan la table et Maj des objets autres que Modbus slave
dataType = groupCurr.datatype
if dataType == "bool" and groupCurr.tags == "-" then
nomGroupe = groupCurr.addr.."/"..idSlave.."/"..i
if grp.find(nomGroupe) then
-- groupe existe
grp.write(nomGroupe, groupCurr.reg)
if dataType == "string" and groupCurr.tags == "-" and i > 1 then
-- groupe existe
-- Scan la table et MaJ registres Modbus slave
-- addr = idGroup, datatype="uint16" , name="I1" ,reg="3000" , unit="A" , tags=""
addRegister = groupCurr.reg
dataTags = groupCurr.tags
-- valeur courante de l'objet WFK
value = grp.getvalue(nomGroupe)
if dataType == "uint16" and dataTags == "modbus" then
-- dt.float16, dt.float32, dt.int64, dt.int32
raw = knxdatatype.encode(value, dt.float32).dataraw
r1 = raw:byte(1) * 0x100 + raw:byte(2)
r2 = raw:byte(3) * 0x100 + raw:byte(4)
mb:setregisters(addRegister, r1, r2)
--mb:setregisters(addRegister, r1)
--mb:setregisters(addRegister+1, r2)
if dataType == "uint32" and dataTags == "modbus" then
raw = knxdatatype.encode(value, dt.int64).dataraw
r3 = raw:byte(5) * 0x100 + raw:byte(6)
r4 = raw:byte(7) * 0x100 + raw:byte(8)
mb:setregisters(addRegister, r1, r2, r3, r4)
--mb:setregisters(addRegister+2, r3)
--mb:setregisters(addRegister+3, r4)
mb:handleslave()
Consider using this script instead: https://forum.logicmachine.net/showthrea...6#pid27726
Your current script does a lot of busy polling via grp.getvalue after each slave step which can lead to timeouts.
Threads: 58
(17.01.2023, 13:35)admin Wrote: Consider using this script instead: https://forum.logicmachine.net/showthrea...6#pid27726
It seemed to me that the problem was there. Thank you for this new version that I will try immediately.
Many thank's too for your help.
Dominique
