Zwave app - copy device parameters
Is it possible to make the following function?
- copy device parameters from another device
or
- save device parameters to file and load device parameters from file
I have a system with a lot of the same devices and all devices needs the same non default parameters.
Its very time consuming to check al 89 device parameters for all devices every time i change something.
Also when i remove and later add a device then my parameters are resetted to default (needs this to upgrade the firmware with another controller). Then i also need to reconfig my parameters. If i can copy it from another device or load from a file it saves me lot of time.
