Threads: 25
24.02.2023, 18:44
(This post was last modified: 24.02.2023, 18:46 by KoBra.)
After updating FB Editor 1 have two problems:
All visual build scripts are not visable anymore. If i click live monitoring i still can see the blocks and the values.
If i build a script and click "Show and generate" nothing happens. If i try to reload the page it says i have unsaved items.
Threads: 25
27.02.2023, 14:45
(This post was last modified: 27.02.2023, 14:49 by KoBra.)
Update from today solved the problem that i can't see the builds. I can Show and Generate a script but as soon as the logic machine is rebooted the script is gone...
Threads: 8
Sounds like a read only SD card, what happens if you create new object and reboot? Is the new object also gone?
Threads: 30
This simple test what Erwin mention will prove it.
Threads: 25
I did but that is not the case, seems FB editor stalls sometimes. Exports the script to json but can't import. Showing the blocks but not saved properly and after restart of FB editor the script is gone...
Threads: 30
Can you send me your backup to PM? It worked for me but maybe it is something related with existing diagrams.
