Plan size limit
I'm preparing control screen for my customer but building plan is too large.For example first floor's background image 16030x 3910 and if i resize , user wouldn't properly use the page.
How can i solve this problem ?
All you care is the ratio of the screen, Enable Usermode auto-size upscaling: in Vis config to fit it in higher resolution screen.
You should make it smaller. Otherwise the backup size can exceed the limits. Choose the right format (JPEG or PNG) depending on the image contents. You can also split a single floor into several plans.
