Threads: 15
I'm preparing control screen for my customer but building plan is too large.For example first floor's background image 16030x 3910 and if i resize , user wouldn't properly use the page.
How can i solve this problem ?
Threads: 28
All you care is the ratio of the screen, Enable Usermode auto-size upscaling: in Vis config to fit it in higher resolution screen.
Threads: 43
You should make it smaller. Otherwise the backup size can exceed the limits. Choose the right format (JPEG or PNG) depending on the image contents. You can also split a single floor into several plans.
