Rotate by css fixed
I rotate an On/Off object by css but when I click on it, it rotate to original position. Is there any whay to fix position?
Add !important to your CSS rule.
(09.03.2023, 11:38)admin Wrote: Add !important to your CSS rule.
I´ve done that but doens´t work
.rotate180{
transform: rotate(180deg) !important;
Works for me as is. See if this works:
.rotate180,
.rotate180:active {
  -webkit-transform: rotate(180deg) !important;
(09.03.2023, 12:48)admin Wrote: Works for me as is. See if this works:
.rotate180,
.rotate180:active {
Hi!
It doesn´t work. I put this class (rotate45) in aditional class but it doesn´t work.  When i click it changes to original rotation.
.rotate45,
.rotate45:active{
transform:rotate(45deg)!important;
  -webkit-transform: rotate(45deg) !important;
Which browser/OS are you using?
(20.04.2023, 12:18)admin Wrote: Which browser/OS are you using?
Chrome, Mozilla and Edge.
It doesn´t work in any of them
Which one do you use?
I see that if I don´t check "Disable object click animation" on Vis. Configuration it works. But I don´t want animations on click.
Use this if click animation is disabled:
.noanim .rotate45,
.noanim .rotate45:active {
