Threads: 4
22.03.2023, 12:51
(This post was last modified: 22.03.2023, 12:51 by F.Braun.)
Hello together,
I had the following problem today..:
At a customer I wanted to program new line couplers, these are equipped with KNX secure.
When I then tried to program them via the controller LM5 the following error message was displayed in the ETS 6: Programming failed. This operation requires an APDU length of 34 bytes, there are only 15 available due to the possibilities of the bus interface. Is there a possibility to increase this APDU length or is this bus interface not able to perform this programming?
Other devices can be programmed without problems.
Threads: 43
Which firmware version are you using?
Threads: 43
You need to upgrade the firmware for the KNX long frame support.
Threads: 43
manos@dynamitec, which ETS version are you using? There are cases when certain KNX devices cannot be programmed with ETS 5.7 but work fine with ETS6.
Threads: 28
What is the HW version of wiser?
Threads: 28
Is LM using latest firmware? Everyone else confirm that it solves the issue.
Threads: 28
HL due to old KNX chip may not work, please try with LM
Threads: 19
Hello Daniel and admin,
I can confirm that using 2023 RC3 firmware for LM and ETS6.06 is working and can download the Z41 Lite remotely. But after the first 8-9 extended frames the download takes about 30min for the application download. I think it does not support the extended frames correctly or something because there are no more telegrams flagged as 'E' on the monitor during the download.
Using ETS 5.5.7 though still not working. I don't understand the issue though since this is not a secure device but indeed it supports extended frames.
For the HomeLynk with old hardware V1, I see that this could be a HW limitation. I have tried to remotely download the Jung secure device using a Weinzierl IP Router 751 and the download is smooth and very fast due to the extended frames. The HL runs on version 2.7.0 and I have not tried with FW version 2.8.0 and ETS6.06. In the end for this site we will install an weinzierl IP interface next to the HL to be able to support the client sufficiently in the future.
Thank you for your support.
Threads: 43
Do you have issues with any other KNX devices in the project apart from Z41 Lite?
Threads: 19
On the site with the HomeLynk I can download the Jung Secure modules if a partial download is done. Only the application download is not possible.
I hope this can help you further.
Thank you anyway for the support.
Threads: 39
(27.03.2023, 10:41)manos@dynamitec Wrote: Hello Daniel and admin,
Z41 is very very long to full program (with any manufacturer interface). It s known issue. After with partial it should be quicker.
SE ECO EXPERT
