Threads: 64
If we have an IP main line (1.0.x) and a LM connected to it and its TP line is 1.1.x we should select KNX connection mode as "IP Routing", isn't it?
If the connect mode is set to "TP-UART", if i'm not wrong, by default all traffic is sent between TP and IP side.
So, in practice, which is the difference between these modes?
Threads: 29
LM mode defines how LM is connecting to KNX, tp-uart is TP and IP, Routing is only IP.
Threads: 29
No, routing is only on IP
Threads: 64
I thought that routing was used as a line copuler between the main line IP and a secondary line TP...
If is not like this in which cases is routing used?
Threads: 29
Just use TP uart when you have TP connected, routing when no TP
Threads: 29
The last sentence is not correct, If you select tunneling then LM will connect to another IP interface via tunneling. You can connect to LM via tunneling always as long KNX IP features are enabled. If you use only secure communication then this will also disable tunneling as this part is not secured yet.
