Homekit app
#41
(16.06.2023, 12:15)balatis Wrote: Hello,
 We have a project using homekit and 1 homepod. After connecting the 2nd homepod, the communication has lost and all the devices in the app show "No response". By the way, the app recognises the homepods and they can play music.
After homekit's reset, there is no change.
The LM firmware is the latest update (20230607) and LM works properly.
I attach you the log from homekit.
Which is the reason for this disconneciton?
Thank you in advance.
The pairing with the homepods has been done properly, and they work.
The communication between LM and Homekit has lost.
The actions we have done : LM reboot , Homekit reset and ipad reset.
We don't have homepod to test it, try deleting the bridge and add it again.
(16.06.2023, 13:38)Daniel Wrote: We don't have homepod to test it, try deleting the bridge and add it again.
I have 6 homepods and it al works great.
But in the architecture there's no difference between 1 or 2 homepods.
Do u use homekit local? or are you connected remotely with the homepod as hub?
We have already deleted and pair again the bridge. There is no probrem with homepod. The bridge worked for 1 week and then the communication between LM and Homekit has lost, as you can see from the image.
(14.06.2023, 16:15)Dario Wrote: Hello,
I would like control Intesisbox interface for Daikin with HomeKit.
Is this possible with "Heater Cooler" device type?
Why there are difference between "Current Heater / Cooler State Status" and "Target Heater / Cooler State Control" value?
I insert also "Cooling Threshold Temperature Control" and "Cooling Threshold Temperature Control" but into Home App I can't control Setpoint, Is it correct?
Yes it is, but you have to use the LM as intermediate interface. Intesisbox and HomeKit use different object types.
it doesn't work either locally or remotely that's why I'm guessing it's a bridge issue
I can’t find it but is there:
A. A possibility to remove unavailable modes when using thermostat?
B a thermostat with integrated fan speed control for airconditioners?
(05.07.2023, 21:28)KoBra Wrote: I can’t find it but is there:
I also need "on-off" funtion for the thermostat device  object ... the default operation mode is not compatable with my airconditioner.
Additionally I need "Fan v2" services (on/off and Fan rotation speed control) which is described in the manual  but I can not choose "Fan v2" from the list of devices.
How the devices looks like is defined by Apple, we cannot modify anything.
Is there any release date planned for getting HomeKit app working on W4K?
(09.07.2023, 18:28)pioneersteffen Wrote: Is there any release date planned for getting HomeKit app working on W4K?
Try with the last version
Many thanks hocine for the hint. Unfortunately I could’t found the download link inside the thread. Can somebody post the files please? Many thanks for the help!
Ask your SE representative, it is SE decision not ours.
(14.08.2023, 07:32)Daniel Wrote: Ask your SE representative, it is SE decision not ours.
Many thanks I will do!
can we have link for offline installation of packages ?
and also a little question, why didnt you choose to add to homekit device setup in mosaic instead of creating again in the homekit app ?
regards
SE ECO EXPERT
Homekit will not work on SE devices.
Not everybody is using Mosaic this is why.
I was speaking about LM package. I have LM+SL+HL at office
Can we have link for offline installation of packages ?
SE ECO EXPERT
https://dl.openrb.com/pkg/homekit-20230607.ipk
(18.08.2023, 12:21)Daniel Wrote: https://dl.openrb.com/pkg/homekit-20230607.ipk
thks
SE ECO EXPERT
I added a Security System device.
Filled in the Required characteristics:
- Security System Current State Status * (uint8)
- Security System Target State Control * (uint8)
- Security System Target State Status (uint8)
with the same knx groupaddress
Before this worked great but last month when i changed the security system with the Home app it continues hangs on: Enabling (or Disabling). But the knx groupaddress is changed.
When i change the security system on the hardware or changing the knx groupaddress then it works great.
Maybe its only the GUI on ios.
