Threads: 28
It is SE, you will need new fw to unlock it again. No new FW is not yet ready
Threads: 4
19.04.2023, 12:11
(This post was last modified: 19.04.2023, 12:36 by NKereshki.)
Many thanks, Daniel.
Did I do something wrong?
Regards,
Nayden
Threads: 28
No nothing you could do, as far I know everyone is affected.
Threads: 76
This is Crazy how SE work in reverse!!!!
Best Regards,
Threads: 28
SE says that they fixed this last Friday. It should work without fw upgrade.
Threads: 4
I get the identical error when installing Touch 3. I had therefore already done a fw upgrade. To latest version 2.8.2. from 31-05-2023. Unfortunately no improvement. Then I searched the forum and read this thread with the identical problem Has it been solved for you yet? If anyone knows a solution, I'd love to hear it.
Threads: 4
I apologize for the late reply. For me the problem is solved, but after I updated the firmware to 2.8.3 there is a new problem with the value visualization in Touch 3. In version 2.8.0 the text of these values was bold, but in version 2.8.3 they are not. This issue is only for the mobile app. They are almost invisible.
Best regards,
Nayden Kereshki
