Threads: 8
I have a problem with the display in the visualization. I have inserted an Https link into a page from my network device at my house. Then shows our connection and cannot open the page. But if I open this link as a second tab in the browser, it is opened and displayed. How can I fix the problem?
Threads: 29
If it opens in another tab then it is something with your browser not LM. Clear browser cache.
Threads: 8
The first time I opened it, I was able to allow it insecurely in the browser, since then I can always open it. But I can't do that in the visu.
Threads: 29
Press F12 and check if you have any errors in the console.
Use SSL certificate app to generate proper certificate so the browser will not complain.
Threads: 8
thanks I'll test it. The visu can be opened and operated, only the page with the frame with the https address is not opened
Threads: 46
Most probably the page is sending a special header to the browser that forbids inclusion via iframe.
Threads: 46
It is a browser security feature that cannot be disabled.
In LM there's a special setting that allows to include one LM in another via iframe.
Threads: 8
okay I have to look for where I can set it
