Scene recall
I'm starting to use scenes to replace a damaged event module with LM, in scenes is it possible to call a scene from another, since they are programmed like this in the event module?
Thank you
To prevent infinite loops one scene cannot call another directly. You can use event scripts to run scenes instead: https://openrb.com/docs/lua.htm#scene.run
what would be the best solution, put all the addresses in a single scene or create multiple scenes to call them via script.
Both in terms of development simplicity and execution speed.
Thank you
If you can use a single scene for all objects then use it.
(25.05.2023, 12:37)admin Wrote: If you can use a single scene for all objects then use it
I try but probaly is a problem use only one scene, I see is possible inside the master scene set a bit to trig other scene, if i try this, have a problem ?
Tank's
