Backup file is invalid
I am trying to load backup from SL (HW is v.3) to HL v.1.3, and I see that Backup file is invalid. Does it mean I can't use backup from devices with new CPU on old devices?
Do we have backward compatibility - can I take backup from HL and use it on SL or LM?
Alex
Backups are compatible. The issue might happen if you try to restore a backup from a newer firmware on an older firmware.
OK, thank you, will check this.
Alex
