MOden on reactor 3g/4g
Greetings
How can I check if the REACTO I'm testing for a customer has GSM or LTE/4g modem
Also is it possible on the reactor to see the modem signal ?
Thank you
Check System config > Status > System log or System config > Status > System status > Serial ports. It might list the modem ports there depending on the model.
For signal level see this: https://forum.logicmachine.net/showthrea...6#pid28906
(08.06.2023, 13:38)admin Wrote: Check System config > Status > System log or System config > Status > System status > Serial ports. It might list the modem ports there depending on the model.
Ok now I check and the LM is 4G modem type.
Unfortunately, however, LM does not receive IP from the mobile network, I tested the sim on a phone and it works, do you need to initialize the modem in the LM?? It has always worked until now, the problem occurred after a firmware update, what could it be due to?
Thank you
Post what you have in System log.
(08.06.2023, 14:21)admin Wrote: Post what you have in System log.
is possible to export the system log ?
Copy-paste entries from the System log window and send via PM.
Go to System config > System > Packages and click the green (+) button. Install updated package, reboot. See if modem connects after the update.
Package: https://dl.openrb.com/pkg/ppp_2.4.9.git-...4_imx6.ipk
Signature: https://dl.openrb.com/pkg/ppp_2.4.9.git-...4_imx6.sig
