Connecting multiple Logic machine
Hey!
I have an object there need to connect up to 8 LM via TCP\IP, with possibility make a one SCADA for all
Which possibility I will have to do this without KNX?
Thank you in advance.
.pdf   Scheme_V2.pdf (Size: 126.66 KB / Downloads: 34)
If LM's are connected to the same LAN they will exchange data automatically via KNX/IP. Another option is MQTT but that will require making scripts and manual configuration on each LM.
