Trend Visulaisation
Hi we have to create trnds chart with voltage L1 and Voltage L2 can you tell me step by step procedure how to create trends and how to add in the UI and how to import scrip where it import
Check LM manual starting from page 48: https://openrb.com/wp-content/uploads/20...3.2022.pdf
For voltage you need to use absolute value trend log type.
what data type have to select (in the object)for my register is 32bit unsigned register
4 byte unsigned integer
Thanks for the replay
Can I get best Graph UI for Industrial measure voltage electricity and power will mostly compare voltages,if we want add script where to add?suggest me with steps,Thanks
Just go to home and click on Trends logs, in there you can compare multiple trends.
Thanks,
I got that,but i want best UI with scripting
It is not very clear what you are looking for so cannot suggest any solution.
Is it possible to see the trends in the Logic Machine app on the smartphone?
Thank you.
Yes
(10.07.2023, 07:28)Daniel Wrote: Yes
Hello Daniel,
but I'm talking about the smartphone App.
On the remote.logicmachine.net website I do see the graphs, but not on the smartphone app.
Is it possible to see the graphs in the smartphone App?
Yes, click X in top right corner to close Mosaic and then open Trend log
(28.07.2023, 10:15)Daniel Wrote: Yes, click X in top right corner to close Mosaic and then open Trend log
Hi Daniel, when I do that, I get an error saying:
"https://remote.logicmachine.net" page says:
Error: log upload failed or access denied.
Make sure you have latest LM Cloud app and it is configured then sync and check again. You need some trends on LM too.
(28.07.2023, 15:34)Daniel Wrote: Make sure you have latest LM Cloud app and it is configured then sync and check again. You need some trends on LM too.
The LM app on my android is Version 1.0.11
I just updated LM cloud to the latest version and re-synced, but I get the same error.
I have tried in another LM and I get the same error
Does it work if you use a browser?
(28.07.2023, 15:51)Daniel Wrote: Does it work if you use a browser?
No, same problem.
But in the lower left corner it says: Connection Ok with the green dot.
This error says that you have no trends to see. Do you have any trends in LM?
Which firmware do you use? What does the log says in LM cloud app?
(28.07.2023, 16:02)Daniel Wrote: This error says that you have no trends to see. Do you have any trends in LM?
I have 33 Trends created.
The LM CLoud Log says:
2023.07.28 17:53:01 config sync finished for trends (1195)
2023.07.28 17:53:00 config sync finished for users (2)
2023.07.28 17:53:00 config sync finished for objectunits (1234)
2023.07.28 17:52:59 config sync finished for objectnames (36277)
2023.07.28 17:52:59 config sync finished for objects (7556)
2023.07.28 17:52:58 config sync finished for mosaic (284200)
2023.07.28 17:52:58 config sync finished for base (37)
2023.07.28 17:49:14 config sync finished for trends (1195)
2023.07.28 17:49:13 config sync finished for users (2)
2023.07.28 17:49:13 config sync finished for objectunits (1234)
2023.07.28 17:49:13 config sync finished for objectnames (36277)
2023.07.28 17:49:12 config sync finished for objects (7556)
2023.07.28 17:49:12 config sync finished for base (37)
2023.07.28 17:49:11 connection OK
2023.07.28 17:49:11 connection started
2023.07.28 17:47:40 config sync finished for trends (1195)
2023.07.28 17:47:40 config sync finished for users (2)
2023.07.28 17:47:39 config sync finished for objectunits (1234)
2023.07.28 17:47:39 config sync finished for objectnames (36277)
2023.07.28 17:47:38 config sync finished for objects (7556)
El LM tiene la firmware:
HW: LM5 Lite (i.MX6)
SW: 20210806
Install 2023 firmware.
