Threads: 21
LM will not automatically update its date and time after being powered on again.
The situation on site is like this: LM is not connected to the network or computer, and cannot update the system time automatically through the ntp service. Is it possible to start a script to automatically update the LM time through the knx address?
Threads: 21
I may not have expressed it clearly. The function I want to implement is divided into two steps:
Step 1. I need to capture the system log information of LM restart and power on, and based on this information, decide whether to trigger the group address to update the time;
Step 2: I update the time through utilities>Date and time>Time (get from system), rather than setting the time arbitrarily myself.
Use NTP, you won't need any manual operations then.
Threads: 21
LM is not connected to the network or any computers, and cannot automatically update the time through NTP. I want to update the date and time through the switch group address on the panel.
Threads: 31
You need local NTP server, the solution you are looking for is not correct.
Threads: 1
05.02.2025, 11:16
(This post was last modified: 05.02.2025, 11:17 by guillermo.)
I already know, it's in the settings! sorry for bothering you!
---------------Hi Daniel, How can I set the NTP server pointing to my own NTP server?------------------
Threads: 31
Just change server to your server.
