1-Wire SE Wiser
Is it possible to get 1-Wire on a SE wiser?
I can find the other way around from 1-Wire to RS485!
No
(28.07.2023, 15:41)Novodk Wrote: Is it possible to get 1-Wire on a SE wiser?
You can use a 1-Wire to Modbus converter. I use two such with 8 thermoprobes each.
Great, can you link me one?
I am using R4DCB08.
https://www.amazon.de/-/en/Channel-Appro...B0953Z7F73
(04.08.2023, 06:52)AISystem Wrote: I am using R4DCB08.
Again, thanks
Does that board only work for temperature sensors?
What if I want to use https://www.mfe24.com/en/shop/48/1/13372662/ will that work?
Again, thanks
This one is specifically for thermoprobes; it won't work with the reader. I assume there are probably similar ones for readers, but I haven't looked.
I suppose something like that will work, but I haven't tested it
https://esera.de/en/Produkte/11606-12/EC...-interface
