Control TV tunner via CEC HDMI from LM5
Hi !
We have a project which we want to control TV tunner via CEC HDMI and I found this article.
https://openrb.com/control-tv-via-cec-hdmi-from-lm4/
This is the example on LM4 but can we do the same thing on LM5?
Thank you for your help in advance!
This solution didn't work well as every manufacture used cec differently so we gave up on it. Most devices got an api which you can use over IP.
Thank you for your reply Daniel!
Okay I understand the situation Smile
I'm sorry to bring this up again, but is it possible to send IR signal with LM5 ?
Or is it possible to send IR signal with RS485 ?
We are still trying to figure out the way to control the TV tuner and IR is also a way.
https://openrb.com/2637-2/
Oh thank you for the helpful link! I wil check it out Smile
