Threads: 130
Greetings
I would like to know if it is possible to change scene switching time from mosaic with the time widget, or if I have to use a script.
Thank you
Threads: 28
What time do you have in mind?
Threads: 28
If you talk about the end user Scenes and the scheduler time then this scheduler is simple a scheduler script, you can find it under scripting. If you modify the scheduler script run time it will work but it will not be updated in Mosaic. If user saves it again from mosaic it will be overridden.
