Issue with Genohm-SCADA-BACnet Package Installation.
After installing the Genohm-SCADA-BACnet package for my LM5 Lite + Ext (i.MX6), I'm encountering some issues. Firstly, I can't seem to see any of the BACnet objects with Yabe. Additionally, Yabe is detecting the LM5 with an incorrect Device ID.
I downloaded the package because I need to write to BACnet objects via scripting. attached a capture from Yabe and BACnet setting of the LM5
(11.09.2023, 13:09)Fahd Wrote: Hello,
After deleting the package, everything returns to normal, is there a way to fix it ?
This is bacnet client package and yabe is also client. Bacnet server is always in, no need to install anything.
(11.09.2023, 13:25)Daniel Wrote: This is bacnet client package and yabe is also client. Bacnet server is always in, no need to install anything.
Then how could I fix this error ,
User script:1: module 'bacnet' not found:
no field package.preload['bacnet']
no file './bacnet'
no file 'Library bacnet'
no file 'Library bacnet.so'
stack traceback:
[C]: in function 'require'
Explain what are you trying to do.
(11.09.2023, 14:38)Daniel Wrote: Explain what are you trying to do.
When I run this script  i face the error that I have mentioned earlier
Quote:require('bacnet')
Quote:valueT = event.getvalue()
Quote:bacnet.write(101380, 'analog value', 78, valueT)
OK then you want to use bacnet client then install this package again but disable bacnet server.
See this: https://forum.logicmachine.net/showthread.php?tid=4530
(11.09.2023, 14:45)Daniel Wrote: OK then you want to use bacnet client then install this package again but disable bacnet server.
I have to use both of them
