Error when frame has some LM pages
I am searching for good solution on LM for unlimited object numer showing. I've tried add to page Room another page(via Frame) with only objects which can have much more height than Room page. The problem is when I am trying start visualisation by exactly link(http://4n.lv:7999/scada-vis/#4) to the Room page, then Frame is not showed(or maybe loaded). When I open the visualisation via Visualisation icon(http://4n.lv:7999/scada-vis/) it is ok and looks like attached. For checking this function I've used demo visualisation from your page so it is possible to check this there.
Can you explain your task in more detail? You can already enable vertical scroll which appears if plan height is larger than window/screen. Including the same visu via iframe is bad practice due to performance penalty for both client device and LM.
(08.12.2016, 11:11)admin Wrote: Can you explain your task in more detail? You can already enable vertical scroll which appears if plan height is larger than window/screen. Including the same visu via iframe is bad practice due to performance penalty for both client device and LM.
I want have possibility to have on 1 page all devices in this room(in some contener) and on the same page static upper and bottom bar. And this should be possible without using function auto-size width and fixed primary background(Because this forces to using auto-size width for whole visualisation, but on some devices this causes situation that some bottom part is not visible when page is loaded).
Perfect would be also to have a function for preparing unlimited size menu, but this is other thing and another subject.
http://forum.logicmachine.net/showthread...light=menu
I see that sliders are one of the most important tools for preparing nice, advanced visualisation which can be competitive with e.g. Fibaro or Gira.
The same situation (error) is with the amatilinea page which is embedded via frameSad
